fi damaged trans :o
Old Jul 18, 2012 | 09:46 AM
Highway Riding's Avatar
Highway Riding
Fuggin gangster..........
Old Jul 18, 2012 | 09:55 AM
djamps's Avatar
djamps
Had to be an impurity or some other defect. So many other weak links in the drivetrain that would normally go first.
Old Jul 18, 2012 | 09:59 AM
f150intally's Avatar
f150intally
Did you drop the tranny without removing the motor? Is this possible with the GTM kit?
Old Jul 19, 2012 | 09:08 AM
ace32x's Avatar
ace32x
yes i did, tranny came out like cake since the imput shaft was severed lol. going back in was a mother f*cker though, the external dump tubes were in the way. i got it to fit in by removing the passenger dump tube and wastegate. i left the down pipes and the driver side dump pipe and external gate in tact. it took 6 hours tough to get the tranny in and bolted up and the dump tube back on. but it is possible!
Old Jul 19, 2012 | 09:09 AM
ace32x's Avatar
ace32x
may have been weakening for awhile, ive had 4 sets of axles on the car now : /
Old Jul 19, 2012 | 03:35 PM
ace32x's Avatar
ace32x
So got everything back in and the replacement heavy duty csc is defective. So after the weekend its all coming back out >.>
Old Jul 22, 2012 | 04:54 PM
ace32x's Avatar
ace32x
got the trans back out again today, make good time got it all the way out in 2 hours, got the slave unit out and it looks like the seal inside the unit itself failed, zspeed has had great customer service through out this mess and is sending me another unit tuesday.
Old Aug 16, 2012 | 08:48 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Thanks for the props but just want to clarify a few things, from my understanding, you ordered the slave from another vendor which was not compatible with the clutch you have. OS Giken twins and triples are shorter in height than the single disk clutches, If you try to install a single disk set-up slave in a twin disk clutch it will blow out immediately when you push the pedal as it runs out of it's designed stroke distance.
The reason yours blew out is because it over extended due to the slave not being the correct height for the application and not due to a faulty part.
We have different versions (heights) of our HD slave cylinder for Single, Twins and Triple clutches. All are different heights because the clutches are different heights.
Old Aug 16, 2012 | 09:36 PM
ace32x's Avatar
ace32x
yep that was found out and corrected when i called back and told them what happened. i ordered it from concept z originally and informed them i had a triple and they said theyd send the correct one. they didnt but when i got in contact with you we got it all squared away right away, and you overnighted the correct one as soon as you had it in which i appreciated. working great now! just need to get that willwood master from you for it now
Old Aug 17, 2012 | 08:41 AM
binder's Avatar
binder
dang, get this beast on the street already
Old Aug 17, 2012 | 09:07 AM
ace32x's Avatar
ace32x
it has been got that issue fixed awhile ago, been boosting around for the last 3 weeks weathers been great up here lately been enjoying it while its here! and working on my ls1 swap into my 240:P
issyz
Jul 2, 2017 03:04 PM
Cashwin
Oct 1, 2015 06:36 AM
