cam effects on compression
Old Jul 29, 2012 | 01:03 PM
jerryd87's Avatar
jerryd87
Default cam effects on compression
i know its been discussed before but here is an example of how bigger cams effect compression ratio at different static compresson ratios. its for a ford 2.0 duratec but it still is a nice example and give people a rough idea of how it works.
Old Jul 30, 2012 | 08:28 PM
binder's Avatar
binder
So by running tomei 264/264 I have a lower effective compression than the 9.5:1 pistons?
Cool to know. I never had the chance to sit down and do all this overlap and lobe stuff with cams on engines. Despite loving physics and math it just seems like a headache. lol
Old Jul 30, 2012 | 08:39 PM
jerryd87's Avatar
jerryd87
honestly i dont even know how to do it all but our cams between the stock lift and duration would be somewhere between the stage 1 and 2 and its over a point of compression drop. so 264s could be in the 1.5 range and i would suspect the 272 possible as much as a 1.75 drop in effective compression. obviously variable cams comes into play as well and can increase the effective compression down low where its needed.
Old Jul 31, 2012 | 07:48 AM
binder's Avatar
binder
so advancing the cams raises compression while reducing cam timing reduces compression?
Is that one of the factors that increases spool in the midrange with advanced cam timing?
Old Jul 31, 2012 | 09:31 AM
rcdash's Avatar
rcdash
I've not seen such data published for VQ cams. Effective compression looks like a time based function (averaged over time). I suspect predisposition to knock would still be based off of peak compression and cam selection would not play a role in this regard (i.e. you would not be able to run a lower octane fuel or run more boost by changing cams or tweaking cam advance).
Old Jul 31, 2012 | 10:02 AM
jerryd87's Avatar
jerryd87
there isnt a chart because no one has made one but this will reduce peak pressures as well. less pressure to start means more peak. it really isnt much to do with time other then the timing of events. advancing the cams will increase compression because the valves close sooner(to a point of course) so you get complete compression, retarding them results in less so the valve could close while still drawing air in resulting in a smaller volume in the chamber. of course duration then has an effect on overlap and will further effect the effective compression.
all of these will add up affecting peak compressions. how much is it going to effect it? untelling thats a "black magic" area and takes some knowledge which i admit i dont have, and some trial and error. i guarantee the ability of forum members to run 10 psi on a stock block is a example, theres alot of platforms with similar compression ratios which would blow. cam selection is also a way some of the exotics can run 12-13:1 compression ratio with no det, no easy task for sure, but they are also set up to make power in a higher rev range, leading to some much larger cams.
Old Jul 31, 2012 | 12:49 PM
rcdash's Avatar
rcdash
At some point all valves are closed, volume is fixed, and the piston is TDC - maximum peak compression cannot change.
Old Jul 31, 2012 | 01:01 PM
meatbag's Avatar
meatbag
http://www.wallaceracing.com/dynamic-cr.php
This is a pretty good calc to use to get dynamic comrpession with different cams. Its not spot on but if wil give you an idea.
Old Jul 31, 2012 | 07:28 PM
jerryd87's Avatar
jerryd87
if that was the case it would be impossible to have different power outputs from the same size engine, and lowering compression ratios would not but they obviously do.
tell me if you take a 1 liter bottle and compress it to 1 square inch, and then take a 2 liter bottle(assume both are full and ignore rupturing and other irrelevant things for now.) and compress it to 1 square inch. which has more total compression?
your view point assumes the cylinder is completely full at all times which it is not hence why VE and VE tuning work. altering cam timing gives you a different dynamic compression ratio, because dynamic includes all variables as well as how much will be able to enter the cylinder. and it is quite likely that the piston will be partially on its compression stroke depending on the cams and timing thus further lowering dynamic compression.
great website meatbag, go ahead and look at it rc, you will see our cams actually allow the intake valve to be open during the compression stroke, 32 degrees to be exact thus lowering the dynamic compression, ie what the engine actually sees. bigger cams are more of a effect, stock cams on my engine for example give me a dynamic/effective compression ratio of 6.5
so with my cams and boost pressure obviously varying spark, at 26 psi boost my effective compression ratio in bost is 17.88, nearing the limit of what meth+ pump can see, its likely i can pull timing and hit 30 psi but ill have to compare on the dyno if 26+ spark is better or 30+ a little less is better. my bet is 30 wins especially considering the massive bump in airflow the billet wheels see around that area.
once i put cams in ill be able to add more spark back in, but honestly i see little to no knock from 26 psi, most of mine was 18 psi which i adjusted and pending the next dyno might go back up if i determine its just engine noise at that level.
Old Aug 1, 2012 | 05:32 AM
rcdash's Avatar
rcdash
Yes, I understand dynamic/effective compression is not the same thing as static compression. With a valve open, air is pushed out. Not questioning that, lol. I just don't fully understand what value the data brings to the table when tuning a car. Seems mostly like guesswork - if you find someone with experience actually speaking to how it has helped them, please post up...
Old Aug 1, 2012 | 06:05 PM
Resmarted's Avatar
Resmarted
Yes.
@Rcdash, a lot of other communities will cite this idea that cams lower compression and actually help knock/preignition etc. It's weird, I think it's pretty silly but some people think it helps.
I've heard some race engine builders talk about running a fat cam with super high compression can help keep then engine from shitting it's-self and I started asking them more about it. They told me if you rely on that to keep things together you're ****ed and it's a negligible difference.
Old Aug 1, 2012 | 06:26 PM
jerryd87's Avatar
jerryd87
my bad at the misunderstanding. as far as tuning? i would say little unless like you said someone with far more experience then i would say 99% of this forum has(im thinking mayby 2 people both shop owners). however looking at how it affects things could further give people insight when planning builds
Old Aug 1, 2012 | 06:27 PM
jerryd87's Avatar
jerryd87
i hardly think a full point to a point and a half of compression is negligible
Originally Posted by Resmarted
Yes.
Old Aug 1, 2012 | 06:43 PM
Resmarted's Avatar
Resmarted
Yeah actually it is.
You loose very little power.
If you are trying to tell me you can feel the difference and see a difference on the dyno from that compression change on the dynamic compression you're really really stretching it.
This isn't a new thing, and overlap has been known to do things like this for a long time. It's negligible in the grand scheme of things.
Old Aug 1, 2012 | 09:22 PM
jerryd87's Avatar
jerryd87
for na sure its a minor loss hardly worthwhile however for fi that is actually a HUGE difference. by dropping the dynamic compression 1.5 points with cams you can run another 5 psi boost to get the same dynamic compression ratio. that combined with the increased rpm of the bigger cams is a significant increase in power i would say 50 hp minimum.
Old Aug 7, 2012 | 07:26 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Wow, this has gotten way out of hand no thanks to 'jerry.'
You have just been warned and penalized for putting the language filter to the test.
As informative as this thread may have been, it's gotten out of control and is losing the point.
This thread is done.
Old Aug 7, 2012 | 09:39 PM
Waiz's Avatar
Waiz
Wowzers
Looks like a few people were bickering like school children
lapham3
Oct 7, 2022 03:15 PM
B Esquire
Sep 24, 2015 07:52 AM
