Maf and injectors for 15lbs on greddy twin turbo kit
Old Aug 9, 2012 | 07:25 AM
HANDSOME's Avatar
HANDSOME
Default Maf and injectors for 15lbs on greddy twin turbo kit
Just looking for recommendations for what is typically used for MAF and injectors for an 05 350z with a greddy kit . It now has a mustang MAF but thats all I know.
Old Aug 9, 2012 | 02:21 PM
thisishk350's Avatar
thisishk350
Uprev makes an upgraded maf that works awesome for high hp. What are you tuning with?
Old Aug 11, 2012 | 06:32 AM
HANDSOME's Avatar
HANDSOME
I have a tuner coming with a portable chassis dyno and that is all I know that he has and my ecu is an e manage ultimate. Thanks for the suggestion.
Old Aug 11, 2012 | 06:56 AM
IslandZavage's Avatar
IslandZavage
If you can, change the E-Manage. It works but there are way better options out there. As far as injectors its up too you and your needs. I run 2200cc injectors but im on pump gas/E85. Usually i see most people doing 440-600cc injectors on stock block and pump gas, but like i said its up too you. What injectors are on the car now?
Old Aug 11, 2012 | 09:11 AM
thisishk350
good luck with that emanage... (in before the boom)
Old Aug 11, 2012 | 10:58 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
For 15lbs I would go with 680-800cc injectors and Uprev ECU reflash would be better than the Greddy unit. Very few if any body use the Greddy units they are pretty archaic For 15lbs you should use something better.
Old Aug 11, 2012 | 11:21 AM
tylerxfire's Avatar
tylerxfire
def. go with something other than emanage...uprev, haltech, etc..
Old Aug 13, 2012 | 09:58 AM
str8dum1's Avatar
str8dum1
emanage ultmate does fuel and timing and is perfectly capable of tuning the car perfectly.
Old Aug 13, 2012 | 10:02 AM
tylerxfire's Avatar
tylerxfire
sure its capable and def. better than the blue but still much better options out there...ive heard many mixed stories about using the emanage for that much boost just like ive heard the same for utec basically...sure itll work
Old Aug 16, 2012 | 07:24 AM
HANDSOME's Avatar
HANDSOME
Thanks for all the replies, i will find out what it has for injectors and maybe just tune fo 10 lbs for this year.
Old Aug 16, 2012 | 09:27 AM
psychoballistic's Avatar
psychoballistic
Assuming you have a built bottom end since your referencing 10-15psi of boost. I would agree that the Emanage is fully capable of tuning the car pretty well, but for money you have in the car already, I would definitely suggest uprev, pro-efi, haltec, vipec, etc... I personally do not like a system that tunes specifically to the MAF as it has no pressure point to reference to, only the volume of air that is being moved. In reality you would have no problem with an Uprev tune, but I would suggest the route of a better ems.
Old Aug 17, 2012 | 10:18 PM
HANDSOME's Avatar
HANDSOME
Ok , I had a pm about the uprev so once we have it at the dyno and have a better idea of what is actually there I will decide then if I am going futher with it. Thanks for the help.
Old Aug 29, 2012 | 06:01 PM
HANDSOME's Avatar
HANDSOME
Default 400 hp
Car made 400 hp at 10 lbs boost but has room for more . He made 480 hp and then the injectors went static so next year bigger injectors and an uprev upgrade.
Old Aug 29, 2012 | 06:17 PM
rcdash's Avatar
rcdash
My understanding is that the E-manage alters timing, does not dictate timing, and that could be a problem as the stock ECU switches maps...
Old Aug 30, 2012 | 09:31 AM
ace32x's Avatar
ace32x
i have a haltech platinum for sale cheap if your interested.
Old Aug 30, 2012 | 02:00 PM
Eno's Avatar
Eno
Define cheap?
Old Aug 30, 2012 | 03:31 PM
ace32x's Avatar
ace32x
Originally Posted by ITNKICN
Define cheap?
cheaper than you will find anywhere on here used
Old Aug 30, 2012 | 03:39 PM
djamps's Avatar
djamps
e-manage blue will add and subtract... e-manage ultimate should have full control like a utec. actually a nice unit.
Old Sep 1, 2012 | 10:44 PM
HANDSOME's Avatar
HANDSOME
Had to leave car at the shop, its burning oil now,hoping its turbo seals.
Old Sep 17, 2012 | 09:46 PM
HANDSOME's Avatar
HANDSOME
Crashed a turbo so it is being sent to greddy so waiting game for now. Does any one know at what boost level the 18 t mitsu turbo is at its max efficiency ?
