With timing correction, what would be the ideal AFR?
Old Jan 8, 2004 | 10:38 PM
elektrik_juggernaut's Avatar
elektrik_juggernaut
Default With timing correction, what would be the ideal AFR?
a lot of Procharger owners have set their AFR's on their complete kits to 11.~:1......this sounds good for a car that has timing advance issues and requires more fuel to quench the heat
I'm planning on getting my ECM reflashed, and since the timing will be corrected, i'm thinking of the old 12:1 ratio more common to other FI setups
I wanna be rich and safe, but not so rich as to kill my O2 sensors left and right.......any suggestions?
Old Jan 8, 2004 | 10:50 PM
spazpilot's Avatar
spazpilot
11.8 to 12.3 is what I used on my turbo Eclipse and is what I am planning on using on the 350z
Old Jan 9, 2004 | 08:18 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
where are you measuring AFR and using what kind of tool?
Old Jan 9, 2004 | 09:02 AM
elektrik_juggernaut
wideband O2 in the exhaust manifold just before the cat, passengers side
Old Jan 9, 2004 | 09:29 AM
Guru's Avatar
Guru
Usually keep it at 11.5-11.8:1 just to make sure to not detonate.
Old Jan 9, 2004 | 10:01 AM
Z1 Performance
Former Sponsor
I would agree.....high 11's would be ideal
Old Jan 9, 2004 | 07:33 PM
daking350's Avatar
daking350
Hey EJ...I bumped up the last two sliders on the DFMU mostly the last one and no more detonation....It seems I tuned when it was 60 degrees out and when it dropped to 30 I ran leaner...No more noise and its about 10 degrees out now here in nj...I amrked my FMU so when it warms up I can set them back but I may be taking the trip to Altered Atmosheres in Feb to get the reflash..
Old Jan 9, 2004 | 10:07 PM
12SecZ's Avatar
12SecZ
I must agree with you EJ after seeing my plugs that 11.5 seems overly rich. This only applies to closed loop mode?
I ask too because I am heading to reflash next week, may go slightly leaner like 11.7-8, you saw my plugs, what do you think?
Old Jan 9, 2004 | 10:11 PM
daking350's Avatar
daking350
high 11's even low 12's sound good as long as you have the timing licked...But then again you west coast 91 octain guys got to be careful..I would stay mid/low 11's on 91 oct..
Old Jan 9, 2004 | 11:06 PM
elektrik_juggernaut
those plugs were wet.........i'm thinking your on the right track sir.......since your timing is pulled in the right areas, a slightly leaner AF might be appropriate........find out what Tadashi has to say about this.....i'm sure he would agree that gas fouled means it's a little too much on the rich side
Old Jan 9, 2004 | 11:27 PM
12SecZ's Avatar
12SecZ
I'm gonna bring a plug with me, he is a "I must see for myself" kinda guy, I like that about him. Already decided. Might gain a fe HP and even better gas mpg, plus extend plug life who knows.
I will bring the plug from #6.
L8TR!
Old Jan 10, 2004 | 07:19 AM
daking350's Avatar
daking350
better hope those plugs werent wet with oil...
Old Jan 10, 2004 | 08:45 AM
12SecZ's Avatar
12SecZ
I already know what those look like Whoot Whoot; and so will you very soon with your guage pod at 1600F Whoot Whoot (snaps neck) , I own you man!
Old Jan 10, 2004 | 03:44 PM
elektrik_juggernaut
gas......definitely gas
Old Jan 10, 2004 | 06:40 PM
daking350's Avatar
daking350
Well that means they arent firing properly..
Old Jan 10, 2004 | 06:59 PM
elektrik_juggernaut
no........that means its running rich.........the car wouldn't run if the plugs weren't firing
Old Jan 11, 2004 | 03:40 AM
12SecZ's Avatar
12SecZ
https://my350z.com/forum/showthread....0&pagenumber=3
There are several plugs in that thread including mine in there, a picture is worth a thousand words.
Old Jan 11, 2004 | 08:14 AM
daking350's Avatar
daking350
Couldnt really tell by the pic Max...Oh by the way how did you get a 9psi dyno sheet when you just did the pulley..
Old Jan 11, 2004 | 08:33 AM
jesseenglish's Avatar
jesseenglish
Old Jan 11, 2004 | 08:46 AM
daking350's Avatar
daking350
Im not stirring up ****..I call BS to here...I would like to know how he got a 9psi dyno sheet @411rwhp putting him at #2 on the top ten FI cars , when him and EJ put the pulley on last weekend with the crawford plenum and he hasnt drove above 3000 rpms..No disrespect intended MAX, just a little FRIENDLY calling out on the BS man
