Turning up b00st....0siris
Old Sep 10, 2012 | 12:19 PM
jninja26's Avatar
jninja26
Originally Posted by tylerxfire
octane aside..if ur turning the boost up then you need to tune for that...if your bringing the car to ny then you might as well wait and go fill up on 93 run thru a tank then fill up again and go to either r/t tuning in pa or performance motorsports in ny for a tune with the added boost and the 93 octane...i beleive those are pretty much your only 2 options for the uprev software
Thanks. I'm just going to use 93 without making any other changes for now. Maybe future drop-in replacement turbo, then new tune.
Old Sep 10, 2012 | 12:54 PM
iideadeyeii's Avatar
iideadeyeii
Originally Posted by taywan
Always ran 93 octane. Yea. I'd say around 5.5-6 & went to about 8-8.5psi.
AFR has always been around 10.2 - 11.2 range.
Your tune might have had an estimated fuel delivery for anything above 140kpa eventhough it was only tuned up to that amount. I've only used MS for tuning before, which can somewhat do that.
Old Sep 10, 2012 | 02:07 PM
jninja26's Avatar
jninja26
In other words, advanced programming to acclimate to changes?
Old Sep 11, 2012 | 05:38 AM
binder's Avatar
binder
Originally Posted by herrschaft
I understand there's little difference between 91 and 93, but to what extent does your statement hold true? What about using 100 octane or higher on the same tune?
No matter how much octane if it is a petroleum based fuel with the same percentage of ethanol (up to 10% from the pump) it will have the same a/f with the same tune.
I haven't done a lot of fuel testing with cars but I've done years of fuel testing on race bikes. With bikes the a/f portion of the tune will not change from pump gas to c16 (116 octane). When using a fuel that is oxygenated that is a whole different ballgame though. Specific gravity plays a role in it but most petroleum based fuels will have close enough specific gravity that any variance in a/f will be small (not enough to actually notice a difference over the atmospheric differences between WOT pulls).
My 93 octane tune runs the same a/f when I run 110 octane fuel in it. The only difference is my 110 octane map has a higher boost pressure. Vac map and boost up to that point is exactly the same.
Old Sep 11, 2012 | 05:56 AM
herrschaft's Avatar
herrschaft
^Good to know, thanks.
Old Sep 11, 2012 | 07:37 AM
athenG's Avatar
athenG
OP, you'll be fine. as long as you dont increase the boost and the timing to much you'll be fine. The octane will not affect the A/F ratio unless you change the type of fuel like increasing the amount of ethanol. Ethanol has a different weight than gasoline so changing the mixture will affect the A/F.
Old Sep 11, 2012 | 10:02 AM
jninja26's Avatar
jninja26
Good information, I'll have to read over this a couple more times.
Indeed
I'm tuned already with osiris by SpecialtyZ, I couldn't adjust timing if I wanted to. From my new understandings I don't need to increase wg (increase boost) at all with 93 octane, nor should I....I'm not get another dynotune right now.
Old Sep 11, 2012 | 03:30 PM
Eno's Avatar
Eno
The way I've understood octane is "safety" not performance. You don't increase performance with octane (alone)- or change a fuels consistency... You simply increase a margin of safety to accommodate more aggressive tunes.
I'm a know nothing- but I've been learning about the same stuff as you are and frankly you can use 93 right now... But you'd just be wasting your money. The boys tuned it safely to 91... Save your money and use 91- even if you have 93 available in ny.
You're a stock block on a used kit- with minimal supporting mods. My suggestion is to stick with this for a bit. Enjoy it. You think you're broke now- blow an engine. Nothing forces your hand quite like 1 step too far.
Old Sep 11, 2012 | 04:23 PM
djamps's Avatar
djamps
Run 93 if you can. Nothing wrong with playing it safe. I use a splash of 103 octane at the track. I don't have to, but why not.
Fuel quality is highly variable depending on season and brand. Why risk your motor on a bad batch if you can prevent it.
Old Sep 11, 2012 | 04:53 PM
jninja26's Avatar
jninja26
I'm going to use my 91map with 93 octane fill ups in NY. Like I said, I'm not about to get another tune right now.
Old Sep 11, 2012 | 04:58 PM
jninja26's Avatar
jninja26
I will be in NY. Like you said, I'll play it safe.
Old Sep 11, 2012 | 07:03 PM
Eno's Avatar
Eno
I agree with the whole playing it safe thing- believe me... Up here the transition between 91-94 is prohibitive... Sort of.
I imagine your tuner was being "safe" too- you say you trust him. I mean- I can take my 99 dodge ram that says 86 and throw 91-93/4 in it all day long... There is no benefit. Just costs more.
In your situation what with boost and all that- yeah 93 is safer. But if you're tuned to 91 you should feel "safe" at 91.
Reminds me of the high angle environment- guys who aren't comfortable tend to want to safe everything quadra- redundantly...
If you pull the trigger and your engine blows up... I would be surprised if octane had anything to do with it. But down there if the price difference is pennies per gallon... Like djamps says it certainly won't hurt
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
