odd oil leak
Old Sep 11, 2012 | 04:31 PM
shakuya88's Avatar
shakuya88
Default odd oil leak
Well, I think I have a good one on my hands (I hope it's an easy one though) so I just got my built motor in the car after 4 months of waiting. Only issue I have now though is an oil leak near the rear of the engine. It only leaks when the car is running, not a drop came out when I was away this past week. Couldn't start it today to see where it is coming from. From what I remember it was either dripping out of where the crank position sensor goes in or from higher up and running down the driver side of the transmission. I believe the ladder. I'm at a loss for where this could be coming from. Any suggestions on where to look now would be great!
Also would oil on the crank sensor cause code P0335 to come up? My brain is fried from this whole thing + still in vacation mode
Old Sep 11, 2012 | 04:45 PM
supraturboman's Avatar
supraturboman
sounds like the rear main seal is leaking. There have been many people installing these improperly, thus causing it to leak. Get a small bottle of oil dye, put it into the motor and take a black light and see where it comes from.
Old Sep 11, 2012 | 05:09 PM
Eno's Avatar
Eno
Sounds exactly like what I just had fixed on my car on a built motor as well. The assumption was that it was the old seal used instead of a new one- as opposed to being put in wrong- but it may just have been a combination.
Old Sep 11, 2012 | 07:16 PM
mx594's Avatar
mx594
Dude,
I just had the same thing happen after I installed my built motor. I rolled the lip on the seal when I put it in, and it leaked. I ended up pulling the motor back out to fix it. See here:
https://my350z.com/forum/engine-and-...estions-2.html
Old Sep 13, 2012 | 05:10 PM
350zion's Avatar
350zion
Professional
This would suck bawls.....
Old Sep 14, 2012 | 06:58 PM
binder's Avatar
binder
I concur. Only 2 oil leaks could come from the bell housing (crank sensor area). The rear main would leak engine oil and the input shaft seal on the trans would leak trans oil. If it's not red tinted and really smelly then it's engine oil. FYI, it's highly unlikely an input shaft seal is to leak so probably a rear main seal or possibly the area around the rear main seal wasn't properly sealed with RTV.
Old Sep 15, 2012 | 07:07 PM
johnwigs's Avatar
johnwigs
oil pan lip seal???
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
