Vortech: 928 vs Si Impeller
Old Sep 26, 2012 | 02:20 AM
wizard's Avatar
wizard
Default Vortech: 928 vs Si Impeller
From the research I've done, it appears to be the 928 which makes more power... is this true?
What about longevity, reliability, etc...?
Old Sep 26, 2012 | 03:18 AM
Quamen's Avatar
Quamen
Thus far the 928 impeller is the only setup that has made 600+whp. The 928 impeller itself is higher quality billet piece compared to the cast Si impeller. Note that the 928 impeller will not fit in an Si head unit though. It was designed for V2 and V3 standard units.
Old Sep 26, 2012 | 11:24 AM
str8dum1's Avatar
str8dum1
there hasnt been a built motor Si car done either though. Granted a billet impeller should have better aero. Still havent seen a stock block 928 dyno that shows any difference over my 460whp Si dyno.
If you built your motor and did cams etc, there would be no reason not to go to a billet wheel. The cost is so inconsequential in the overall price.
But if you did build your motor, going to a Ysi blower is the much more logical solution.
Old Sep 26, 2012 | 12:17 PM
350zhp306's Avatar
350zhp306
Your 457whp was done on Sharif DD => what is the equivant dynojet whp/tq numbers?
Old Sep 27, 2012 | 02:12 AM
wizard's Avatar
wizard
Is this the Vortech v7 blower you refer to? - It's quite expensive isn't it? What sort of power have people made on a built VQ? - Or is this uncharted territory too?
Old Sep 27, 2012 | 12:20 PM
djtimodj's Avatar
djtimodj
Hi Ray!
More boost!!!! lol...
Old Sep 27, 2012 | 06:11 PM
HaroldStewar's Avatar
HaroldStewar
Calinismo350z
Sep 14, 2015 04:04 PM
350z006
Nov 2, 2009 11:40 AM
Quamen
Oct 28, 2009 06:18 AM
Quamen
Jan 30, 2009 01:18 PM
