utec base map
Old Nov 8, 2012 | 10:01 AM
skaterZ04's Avatar
skaterZ04
Default utec base map
i am doing a twin turbo build this winter, i have the gtm stage 1 kit. and i have 600cc injectors. i am using utec for the time being, yes i know its not that great . but thats what i have. anyways, on the website they have a twin turbo 440cc base map and a single turbo 600cc base map. im not sure which one would be better to use for a base map. when i install my kit. any help would be great.
Old Nov 8, 2012 | 11:07 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
600cc st
Install, test the tune and limp it to a shop to get tuned. Basically all you need is to be able to start, idle and drive under 3krpm
Do not expect to drive it hard on a pre-made tune.
Utec is not that bad. The interface is the worst part but its simple once you get used to it. Not as pretty as a haltech but it works. It used to be the bee's knees before Fcon,haltech and proefi.
And for the price that they go for, you really cannot beat it.
Old Nov 8, 2012 | 01:00 PM
djamps's Avatar
djamps
Originally Posted by Cux350z
600cc st
If it's not too long of a distance (<50 miles?) you can drive it untuned on the OEM ECU then pop the UTEC in at the shop. As long as you are light and easy on the throttle you can avoid going too rich.
Old Nov 8, 2012 | 02:01 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
^good luck with 600cc injectors
Old Nov 9, 2012 | 10:53 AM
str8dum1's Avatar
str8dum1
good luck with what? I drove for a week on stock ecu and 600cc injectors with no issue except fast tip in was too rich.
certainly zero issue driving to a tuner.
Old Nov 9, 2012 | 12:56 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Almost twice the fuel and everything was ok? I didnt try to run on 600cc and stock ecu but i just do not see it being fun.
Old Nov 9, 2012 | 10:34 PM
skaterZ04's Avatar
skaterZ04
thanks guys for all the help. the shop i was going to get it tuned at is about 6hours away. only other closet place is about 3hours away. i live in west texas, its either dallas, san antonio, or houston. 3, 5, 6 hours away. so it will be a long drive. i have some friends that are diy tuners in town. but def not professionals.
Old Nov 10, 2012 | 04:59 AM
djamps's Avatar
djamps
Do you have an A/F gauge? If you do, try driving on the stock ECU and see if you can keep it at/near 14 when cruising. If you can, you will be fine for the drive. Otherwise get one of your DIY tuners to help you get the UTEC setup. You don't really need a base map to limp it to the tuner. Aside from reading the manual 100%, Put it in speed density mode with a cutover of 0psi, pull a bunch of fuel from the 1st column, and stay completely out of boost.
Old Nov 10, 2012 | 06:49 AM
skaterZ04's Avatar
skaterZ04
i have the utec all setup right now and im running the intake and exhaust base map off turboxs.com and i dont have my af ratio gauge at the moment but i wil install it before the kit.
Old Nov 12, 2012 | 03:26 PM
str8dum1's Avatar
str8dum1
yup, i drove from NC to FL that way back when Jeremy Tibbs was the go to guy for tuning. LOL
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
