How much are people paying for a TT installation and tuning??
Originally Posted by z350boy
To do a TT install right the first time you will need (at minimum) the following:
(1) Greddy TT kit ( spark plugs, fuel pump etc) - $5,100(tt kit)
(2) Tuning - $1,500 (est)
(3) Intercooler - $1,325
(4) Engine management system ( ie Greddy, Utec ) - ???
(5) Engine management guages ( ie Defi, AEM) - $1,000
(6) upgraded clutch & flywheel (ie RPS ) - $1,500
(7) Greddy TT exhaust - $1,200
Total Estimated Cost: $12,000
You may also need to upgrade:
(a) Cooling system - especially if you live in a hot climate
radiator ( ie Koyo) - $450
oil cooler (ie Nismo, Stillen, ARC) - $300
power steering cooler ( ie Nismo, Stillens, ARC) - $200
Total Estimated Cost: $950
Note: Your TT kit should have all the associated hardware.
Hope this helps!!
Hope this helps!!
is one particularly easier to install than the other?
what would be the bare minimum to install one of these kits?
thanks
if you think 3k for a greddy kit is too expensive then you prolly dont need to have a greddy kit. Most shops will tell you alone the wastegates are a PITA but hey its your car your motor your money.
Originally Posted by Cube
Your math only allowed $400 for UTEC
$9600 out the door for Stage I installed and tuned to wastegate pressure. Safe, cheap, and effective.
Originally Posted by Le Zed
I wanna raise this back up. I innitially was looking into Single Turbo, but I guess from the research I've seen the way to go is twin, never the less. Since there are more out there and more experience.... How much would it cost to install a general twin turbo 4 years leter after this thread was started?
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
