greddy twin build...
Old Aug 18, 2013 | 05:54 AM
  #101
herrschaft's Avatar
herrschaft
Originally Posted by OldManZ350
Hard to tell from the Video, just know their is something not right.
So, what do you think it is?
Don't know, but my auto never made that sound.
Old Aug 18, 2013 | 09:38 AM
  #102
bealljk's Avatar
bealljk
was aware of that when it happened…will keep an ear out my next start up…could be ps the system was drained when I was tearing everything down and filled a few weeks ago…
I will post a few more videos of my next start up / start ups…thanks for the heads up and possibly solutions…to think everything was going to fire up just fine and run perfectly from day 1 would be foolish
it's a 6speed manual, not an auto -
Old Aug 20, 2013 | 07:43 PM
  #103
bealljk's Avatar
bealljk
confused would be a good way to describe the feeling…
Its hard to explain, but I had to reverse wire the passenger side pump bc how it sits, it's opposite of the drivers side but the hoses are not backwards…and I started going in circles on my psyche 'did you switch the wires?' 'did you forget to switch the wires'…and I damn near talked myself into thinking I did…so I switched them back and ran the pump dry…sure as ****, I did indeed switch the wires so the pump was working right…and at this point I checked both pumps and they were functioning as intended…
A local guy, DKmura, suggested a fire extinguisher which I thought was a good idea…infact, 2 of them…a small 30second one for anything small and a big one in case **** hits the fan…
my buddy Tom out in Croatia who saw the rough running video said to remove the serpentine belt and run the car briefly to rule-out either the power steering pump or the alternator…which I thought was a great idea…
but I figured I should get another baseline video of the car as to compare belt on versus belt off.
I removed the fuel pump fuse to build some pressure in the system, replaced and restarted…
took a few extra seconds to start and an on-going issues with my starter (or flywheel) with what I believe is missing a tooth happened(right around minute mark 0:15) but the car started up just fine…I cranked the steering wheel left and right a few cycles to fill/bleed out the steering cylinder…
idle was initial bouncing between 600rpm and 1800rpm as was the oil pressure between 60 and 100psi…but it seems that everything is running smooth and no awkward metal sounds…the car ran for a minute or two and the engine idle simmered down and was consistent at approximately 600rpm which is rare…
Please take a look at this video (maybe watch the other video first to compare to)
a little more burn off from what I believe is the silicone spray used on the exhaust wrap...
Old Aug 26, 2013 | 05:56 PM
  #104
bealljk's Avatar
bealljk
We complete our move…I wont have a garage for a few months here and the car is down in storage (along with the other toys)…sad sight…
and scoped this off ebay…will place right before the turbos…wont give me complete security the turbos are getting oil but it'll help…
Old Dec 11, 2013 | 08:13 PM
  #105
bealljk's Avatar
bealljk
picked up a mac boost controller…
if the whether cooperates it should be a week or so…knock on wood…before the garage is done and I can get back to the build...
Old Feb 21, 2015 | 06:20 PM
  #106
bealljk's Avatar
bealljk
well...I guess CONOC (Colorado Nissan Owners Club) crapped the bed ... So I guess I better update this thread from where I left off...
Old Feb 22, 2015 | 06:42 AM
  #107
Escobar's Avatar
Escobar
dont know how I missed your thread man. Pretty nice work! I didnt realize you fabbed up so much custom stuff. impressive!
Old Feb 22, 2015 | 05:04 PM
  #108
Escobar's Avatar
Escobar
good call on the fire extinguishers. that would suck to have a fire and have to watch it burn after all that work. here is a shot of mine. Its a halotron "clean agent" extinguisher. Its a gas that leaves no residue, no mess. Safe for electronics as well. Pretty pricey but worth it. It will knock down a engine fire quickly with no mess to clean from those powders.
Old Feb 22, 2015 | 10:19 PM
  #109
SAMzG35's Avatar
SAMzG35
Did you replace the exhaust/head studs? I'm installing mine now and the stock studs are too long.
Old Feb 23, 2015 | 10:08 PM
  #110
bealljk's Avatar
bealljk
I responded to your thread...thanks for checking in, there is much much more to post...
Old Feb 23, 2015 | 10:59 PM
  #111
terrasmak's Avatar
Impressive fab work
Old Feb 24, 2015 | 05:34 AM
  #112
bealljk's Avatar
bealljk
^it looks worse in person...I'm honing my welding skills and working with a guy who is teaching me a few things...
Old Feb 24, 2015 | 01:46 PM
  #113
str8dum1's Avatar
str8dum1
ya, my buddy had more damage from using an ABC extinguisher than from the fire itself.
Old Feb 24, 2015 | 02:35 PM
  #114
Escobar's Avatar
Escobar
yea I bet. they make a big mess. that powder is nasty. Not recommended for cars lol.
Old Feb 24, 2015 | 06:33 PM
  #115
bealljk's Avatar
bealljk
I dont know if I have pictures of it but I found a guy who retired an FC RX7 SCCA car and he hooked me up with his in-car suppression system...
So the car sat for the late 2013 / early 2014 while a garage was being constructed. I'll skip ahead to the relevant stuff...
But spring 2014 got back on it...not sure where I went wrong whether something back when I first put the turbos on or sometime between then and spring 2014 but pretty sure I lost my headgaskets...
out comes the block ...
Old Feb 24, 2015 | 06:59 PM
  #116
bealljk's Avatar
bealljk
Went with the HR gaskets
heads at the shop to get machined
new gaskets sprayed with copper sealant
fab'd up some AN fittings on the coolant hard pipe...one for a pathfinder mod and one to more easily bleed/vacuum out air bubbles...
eliminated the second coolant hard pipe, added the AN20 fitting and remade the coolant pipe
Size:  124.9 KBEliminated the coolant bypass line and heater core line and fab'd up a simple bracket to cover it up.
had to remove the transmission as the waste gates wouldnt have fit around the bellhousing of the tranny...
while the engine was out had the flywheel resurfaced and during the install I stripped the helix coils out of the flywheel...this is a JWT clutch/flywheel combo and we did the reinstall per their instructions...I'm not upset with JWT but the machinist that cleaned everything up said put 20 ft*lbs and use blue loctite...
Old Feb 25, 2015 | 01:23 PM
  #117
Escobar's Avatar
Escobar
cool! looks good man. so your head gaskets went bad while it was sitting??
Old Feb 25, 2015 | 08:42 PM
  #118
bealljk's Avatar
bealljk
With everything back on and bolted together I had to get the fans going...wasnt sure what manner I was going to proceed but I decided to go pretty stout (which was a mistake in hindsight).
I sourced these server cooling fans - which are your normal computer cooling fans but on steriods - they move some air! Created a template and found a sheet of aluminum from a metal supply outlet in denver. punched and drilled my cores and Name:  IMG_8624_zps1b4d9f5a.jpg
Fitting wasnt too bad but sorta a pain in the ***...
All got scrapped it was 26lbs on the front end of the car (where I'm doing my best to reduce weight on my front end. Found this 16" spal puller and a little sheet aluminum...
Old Feb 25, 2015 | 08:56 PM
  #119
bealljk's Avatar
bealljk
Added a vacuum block, catch can/valve cover vent
Old Feb 25, 2015 | 09:07 PM
  #120
bealljk's Avatar
bealljk
Added flex hose sections to the test pipes and down near the resonators.
