Need help with twin turbo 350z
Old Feb 5, 2013 | 08:12 AM
2006treefidyz's Avatar
2006treefidyz
Default Need help with twin turbo 350z
So I put twin turbos on my 350z and it is smoking like crazy especially when you hit about 2500 RPMs.. it is using oil like crazy as well.. I have noticed that oil is blowing through my charge pipes and dont know how to stop it. It has a catch can so that isnt the problem.. I have also noticed that when it hits between 3000 and 4000 RPMS it starts to sputter and has a hard time getting above that.. but once it does it doesnt sputter.. it has the full greddy turbo kit and the profec boost controller.. if someone can give me some ideas that would be great.
Old Feb 5, 2013 | 08:32 AM
wird06's Avatar
wird06
Sounds like seals are gone in the turbo, or the turbos are not draining properly, its seeing to much backpressure and blowing past the seals.
Just my 2 cents
Old Feb 5, 2013 | 10:15 AM
bmccann101's Avatar
bmccann101
w a car like that, youd best be on first name basis w people at a local shop that deals in boosted VQs.
Old Feb 5, 2013 | 11:30 AM
2006treefidyz
Just my 2 cents
Yeah that is what im afraid of.. they are brand new turbos have less than 100 miles on them. But thanks for your help
Old Feb 5, 2013 | 12:58 PM
iideadeyeii's Avatar
iideadeyeii
Ball bearing turbos? Did you install a 1mm restrictor on the feed line?
Old Feb 5, 2013 | 02:42 PM
rcdash's Avatar
rcdash
Need appropriate restrictor on oil feed, depending on the turbo.
Need to release crankcase pressure. See catch can threads in FI section.
Old Feb 7, 2013 | 10:04 AM
str8dum1's Avatar
str8dum1
since when are greddy turbos ball bearing?
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 28, 2015 03:03 AM
