Anyone ever snap or bust a timing chain on 350z?
Old Feb 19, 2013 | 05:35 PM
BeastlyZ's Avatar
BeastlyZ
Default Anyone ever snap or bust a timing chain on 350z?
I was wondering if this has happened to anyone and what could cause it to happen. Block only had about 27k on it. This is a built engine and was coachk's old car. Any suggestions or help would be greatly appreciated..
Old Feb 19, 2013 | 08:11 PM
TuckerE36's Avatar
TuckerE36
Maybe since this was a "built" motor, when whoever reassembled it they over tighten the chain tensioners or the chain. Or the tensioners, guide, ect were installed incorrectly.
I was under the impression that the timing chain should never have to be replaced, a R.U.F. (Run Until Failure) part if you will.
Old Feb 19, 2013 | 09:04 PM
jerryd87's Avatar
jerryd87
my stock one had 101k on it when i replaced it, it streched some but dint snap, the tensioners are hydraulically adjusted impossible to put to much tension on them. guides are pretty damn hard to install wrong too, something is definitely going on for it to just snap best bet would be manufacturing defect.
Old Feb 19, 2013 | 09:51 PM
BeastlyZ's Avatar
BeastlyZ
Waiting to see exactly caused the mechanical failure...Shop it's at right now is saying 11 hours to take heads off to see if valves are bent..
Old Feb 19, 2013 | 10:18 PM
TuckerE36's Avatar
TuckerE36
11 hours!? Geezz are they gonna stop in the middle of break down and go to Happy Hour??
Old Feb 19, 2013 | 10:54 PM
BeastlyZ's Avatar
BeastlyZ
What is the norm time to take heads off Tucker..?
Old Feb 20, 2013 | 04:56 AM
TuckerE36's Avatar
TuckerE36
It should take a good shop on average of 6+ hours to swap heads, so if they're just pulling them off, i'd be worried if they're quoting you 11 hours...Maybe they're just gonna take their time but on your dime.
Old Feb 20, 2013 | 06:12 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Unless they're quoting total time to remove and reinstall the heads?
Old Feb 20, 2013 | 10:51 AM
TuckerE36's Avatar
TuckerE36
The OP made it sound like it was going to take the shop 11 hours just to take the heads off and look at the valves, BUT that could be the time to do a R&R on the heads. I guess it just depends on the mechanic and how equiped the shop is.
Old Feb 20, 2013 | 11:42 AM
bmyles's Avatar
bmyles
I got a quote from a reputable shop for $1500 to do cams. That equates to roughly 15 hours, so to R&R the heads, doesn't sound too far off.
Old Feb 20, 2013 | 09:42 PM
BeastlyZ's Avatar
BeastlyZ
So the car is at Precision R here in town and got a call from them today saying that they would have to take motor out due to the APS twin kit that's in the car. They said the exhaust valves looked good and will look at the intake tomm. Really hoping we just have to replace timing kit. I will ask them to do a compression as well just to make sure no valves are leaking...If the engine is totally ****ed though I will be parting out APS twin kit and other forged internals that are on car and just drop in stock DE.
Old Feb 21, 2013 | 06:17 AM
meatbag's Avatar
meatbag
Ive had a timing chain snap before. Dont know if anyone else has that ive heard of.
Old Feb 21, 2013 | 07:32 AM
BeastlyZ's Avatar
BeastlyZ
What did they tell you meat bag..? How did t occur? Damage that was done? More info please..
Old Feb 21, 2013 | 08:03 AM
BeastlyZ's Avatar
BeastlyZ
Oh and they told me they found a bolt in the middle of the oil pan..Not sheared or broken but intact...Now they are saying there might be lower end damage..
Old Feb 21, 2013 | 08:07 AM
Junkster's Avatar
Junkster
^ouch! My guess is maybe the bolt came loose and got caught in the chain...maybe the builder forgot to torque something down on that side? ie water pump or something?
Old Feb 21, 2013 | 08:49 AM
meatbag's Avatar
meatbag
Was on a customers car. New chain with maybe 2500 miles on it. Happened when he was cruising down the highway. Looks like it links just tore apart so it could have been a weak spot in the metal. Ended up bending the valves in one heads but everything else was fine.
I see this happen when someone doesnt tighten the guides down all the way. The bolts on the guide above the water pump tends to come out first in that situation.
See above.
Old Feb 21, 2013 | 08:57 AM
BeastlyZ's Avatar
BeastlyZ
I am seriously thinking about just putting in a stock de and selling everything off this car..Coachk did a tremendous job with it but looks like the dame chain ****ed her over..There is a lot of money in this car...Complete Nos kit as well..
Old Feb 21, 2013 | 05:45 PM
TuckerE36's Avatar
TuckerE36
Dang that's really unfortunate... I wouldn't throw in the towel just yet!
Old Feb 21, 2013 | 10:21 PM
BeastlyZ's Avatar
BeastlyZ
Thanks Tuck..Actually the guys said the valves look to be in good shape..SO after compression and flowing the heads we shall see..
Old Feb 22, 2013 | 12:21 PM
Junkster's Avatar
Junkster
See above.
man that sucks....
