vortech SC trim for rev-up???...limits??
Old Mar 11, 2013 | 10:32 AM
Sequence's Avatar
Sequence
Default vortech SC trim for rev-up???...limits??
So, last year i purchased a used vortech v2 head unit( polished and in great condition) and started building my kit, and now it's all finished, i've finally completed it. Just waiting for spring to install.
ONE PROBLEM(possibly?)....without even thinking about it until this past week, I just found out that it's an SC-trim.(not sc-i)
This is going on an '06 Rev-up. my power goal is around 400whp/340-50wtq. Are there limits with this SC blower trim for my goals? I know with the newer head units on a Rev-up you can put 400whp down with the 3.12 pulley quite easily(with supporting mods). Will i be able to pull this off with the 3.12 pulley still, or will i have to jump up to the 2.87?
I'm slightly concerned about this right now, especially after buying mostly new parts to finish off this kit.
Old Mar 11, 2013 | 11:13 AM
Triji's Avatar
Triji
There are people running the SC trim blowers up to 500 - 600whp with the 928 impeller upgrade. You can also change your cog set up, if you have the rev-up kit, from 34/32 to a 32/28 tooth set up for more boost. The potential is definately there...
Old Mar 11, 2013 | 11:31 AM
Sequence's Avatar
Sequence
hmmm.....changing that cog setup is the same as running 2.87 pulley though, is it not? My thing is, i didn't want to run a crazy amount of boost. i've been reading so much of guys with rev-ups running 3.12 and putting down great numbers....guess i should have dug a little deeper.
Old Mar 11, 2013 | 11:32 AM
Sequence's Avatar
Sequence
.....i don't mind if i have to be running a 2.87, as long as boost isn't over 11/12 lbs
Old Mar 11, 2013 | 12:13 PM
Triji's Avatar
Triji
You can always send the blower into Vortech and have it upgraded to sci trim for 400 bucks or so I think it is.
Old Mar 11, 2013 | 12:34 PM
350z006's Avatar
350z006
For 400whp you'll be fine...
Old Mar 11, 2013 | 12:48 PM
Sequence's Avatar
Sequence
I'm going to assume you're saying this based on me going with the 2.87 pulley?
If this blower will perform to 400whp, then I will keep it as is for now, at least until i have the urge for more and at that point i can upgrade the impeller. I just hate the thought of sending it in at this point for the upgrade.
Old Mar 11, 2013 | 12:49 PM
Sequence's Avatar
Sequence
I'm hoping to not have to do that right now. hope to be able to pull it off without upgrading the impeller. that will be my last resort at this point.
Old Mar 11, 2013 | 02:20 PM
Colombo's Avatar
i made 425/356tq on a stock block DE with the 2.87 u should be fine, many have and are doing it.
Old Mar 11, 2013 | 02:36 PM
Sequence's Avatar
Sequence
Hey Colombo, was that with an older SC trim though? I know many people are doing it with the newer trims, but haven't heard much on the SC trim without upgrading the impeller and that's more my concern.
Old Mar 11, 2013 | 02:48 PM
350z006's Avatar
350z006
I also made ~400whp on my stock block with my V2 SC trim with just a 2.87...it's the bigger +500whp build that will need the impeller/blower upgrades...
Although OldMan350z did overspin his stock blower up to ~500whp
Old Mar 11, 2013 | 02:52 PM
Colombo's Avatar
myself and many others did it on the SC trim.
Old Mar 11, 2013 | 02:53 PM
Colombo's Avatar
^^ didnt see this. what he said ^^
Sequence's Avatar
Sequence
Awesome, thank you! and thanks for all the responses from everyone as well. not as bad off as i thought i was.
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Calinismo350z
Sep 14, 2015 04:04 PM
torchkc
Sep 11, 2015 08:26 PM
