Greddy TT which test pipes
Old Jul 21, 2013 | 07:35 PM
buffhulk's Avatar
buffhulk
Default Greddy TT which test pipes
So I just got done looking at the boost for noobs thread and I didn't see anything on this topic.....does it matter what test pipes you use I trying to get the most power out of this kit on a stock block as possible....I'm running 550cc injectors,walbro 255, uprev tuned by Zfever.....had a supercharger thought I was done with FI but got a turbo kit and need good advice thanks
Old Jul 22, 2013 | 06:41 AM
djamps's Avatar
djamps
any test pipes will fit (even stock cats will) but you want as free flowing exhaust as possible... 3" test pipes and dual 3" exhaust would be ideal.
Old Jul 22, 2013 | 08:38 AM
str8dum1's Avatar
str8dum1
you could run full stock exhaust and still break your stock rods with that kit.
dont worry too much about spending much on test pipes or exhaust.
Old Jul 22, 2013 | 02:23 PM
buffhulk's Avatar
buffhulk
Even on 5.5 psi which is considered safe by greddy
Old Jul 22, 2013 | 03:39 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Only thing is safe is if its parked in a garage
Old Jul 22, 2013 | 05:57 PM
J rad's Avatar
J rad
I have aam, 400hp on stock block. Keeping my fingers crossed.
Old Jul 22, 2013 | 07:03 PM
buffhulk's Avatar
buffhulk
Then ill get those did it come with the o2 extenders to prevent check engine light
Old Jul 22, 2013 | 07:49 PM
binder's Avatar
binder
str8 is trying to point out it is wasted money. If you are making 5.5 psi and 400hp you don't need test pipes. So you are wasting money on something you won't use because it's not needed for small boost like 5.5 psi.
Old Jul 22, 2013 | 07:54 PM
djamps's Avatar
djamps
running stock cats or HFC on this kit is a bad idea IMO... quick failure unless the tune is perfection. test pipes will let you get away longer with the average tune.
Old Jul 23, 2013 | 10:05 AM
buffhulk's Avatar
buffhulk
Well I'm gonna do the Aam **** it it's only 200 bucks
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
