ams crank pulley with vortech
Old Sep 18, 2013 | 02:15 PM
35thsickz33's Avatar
35thsickz33
Default ams crank pulley with vortech
I was wondering does anybody have a ams light weight pulley with there vortech ?? not underdrive I ready know it would lose boost, I had one on my other z for 70k no problems and the new owner said its still going strong even though ever one said It was going to mess something up never did rev'd alot faster lost about 5-6lbs .
Old Sep 18, 2013 | 02:46 PM
jerryd87's Avatar
jerryd87
you didnt loose 5-6 pounds going to a lightweight pulley, the stock pulley weighs 6 pounds and you where hurting the engine guaranteed if you tore the engine down you would see accelerated bearing wear. how accelerated depends how much power you where making it, simply saying "oh it was fine and still running" without tearing the engine down is a false statement. more power you make the quicker a issue will arise.
any faster revs you noticed was either free revving which absolutely dosnt matter since the car dosnt move in free rev, or its your brain making you think it revved faster because you spent money which has been covered a couple times and is a pretty common psychological action when modifying something "feeling" that it provided a positive benefit where actual testing shows no difference or worse performance.
to answer your question theres no reason it shouldnt work but its highly ill advised.
Old Sep 18, 2013 | 03:55 PM
IcanHaz's Avatar
IcanHaz
I have a vortech with the ams light weight pulley set and I have never had any issue.
Old Sep 18, 2013 | 05:45 PM
35thsickz33
The weight loss was 5lbs I have a stock pulley laying around and its slightly under 7lbs and the ams pulley weight is 1.70. I think if it did damage anything it would have messed up by now , I installed it at around 100k and sold it at around 173k and now has over 200k the car made 291 and 273lbs on the dyno and I never babied it lol . It felt like it went thru rpm's quicker but maybe it didnt . I just want to make max power on my vortech with 3.3 stock pulley for now
Old Sep 18, 2013 | 05:47 PM
35thsickz33
How many miles with the vortech nd ams pulleys??
Old Sep 18, 2013 | 06:53 PM
OldManZ350's Avatar
OldManZ350
He does not get it.......
Old Sep 18, 2013 | 06:57 PM
OldManZ350's Avatar
OldManZ350
That is the Lowest Hp I've seen for any 350z with a Vortech kit.
VQ35DE Vortech Kit's makes 325-330whp with 3.33 pulley "out of the Box" on a totally stock "z" and no tuning.
You do have a lot of miles.
Old Sep 18, 2013 | 07:19 PM
IcanHaz's Avatar
IcanHaz
So far only 7k miles with vortech and ams pulleys but I've had the pulleys on for about 15k miles. My car makes 425whp with a 2.87 pulley and has 83k on the odometer if that helps.
Old Sep 18, 2013 | 07:26 PM
IcanHaz's Avatar
IcanHaz
Also according to AMS the weight difference between the ams crank pulley is 1.84 lbs vs. 4.46 lbs stock pulley. 4.46-1.84= 2.62 lbs.
Old Sep 19, 2013 | 12:04 AM
35thsickz33
ooo noo those aren't my number on my vortech z that was my n/a z before I sold it was trying to tell him with all those miles no problems accured with the pulley.
I was just asking if any 1 did have one with the vortech and ran into problems .
Old Sep 19, 2013 | 12:10 AM
35thsickz33
I don't know where you get your info but this is off the ams site Main crank pulley weight is 1.84 Ibs vs. 6.24 lbs stock,Total weight of kit is 2.52 lbs vs. 7.54 lbs stock . my stock pulley weighs just under 7lbs slightly heavier than what said
Also thanks for the info I think I might get it installed here in a week or two I have a brand new one just laying around might as well put it to use
Old Sep 19, 2013 | 12:17 AM
35thsickz33
you looked at z1motorsports for the weight I think they got it wrong because on the other pulleys they sell it says 6.25 for the de lol
Old Sep 19, 2013 | 10:18 AM
IcanHaz's Avatar
IcanHaz
No problem, Lol yes sorry about that I did look on the z1 website for that information.
Old Sep 19, 2013 | 10:47 AM
evilscorp's Avatar
evilscorp
Running 360whp for 2800miles with the ams pulley but I will be swapping to the fluidampr dampened pulley for safety and to spin my blower faster. As stated can't tell if its wearing the crank bearings unless you strip it before and after.
Justin100
Nov 25, 2021 06:26 AM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
