interesting post from scott porter racing
Old Nov 2, 2013 | 11:28 PM
jerryd87's Avatar
jerryd87
Default interesting post from scott porter racing
seems like factory pistons are actually pretty damn stout if your using e85 or race gas so rods really are the only weak part of the vq35
The new SPR dragster licencing was completed yesterday with the first 2 full passes being:
6.85@196 and 6.71@203.... Factory crank and pistons, rods, heads, cams and turbos from the very first times that we ran the Infiniti.... Can't wait to put some power in it this weekend at Jambo with a good motor!!!
Prep day today to test the Infiniti tomorrow with the second brand new 4.0 litre combo, new heads etc etc
We'll get some footage of the test passes up soon.....
Old Nov 2, 2013 | 11:32 PM
jerryd87's Avatar
jerryd87
also i think i found the reason he can do 235 mph but not hit 5 second 1/4 yet lol kinda hard when your flying not driving
Old Nov 4, 2013 | 01:27 PM
meatbag's Avatar
meatbag
I am pretty sure they just didnt word it right. I bet its factory crank and everything else is aftermarket. If its stock pistons then more power to them.
Old Nov 4, 2013 | 01:56 PM
jerryd87's Avatar
jerryd87
thats what i read it as is stock pistons and crank and then they took the rods, heads cams and turbos from a previous setup. i know they use factory casting de heads granted they without a doubt have some massive work done to them. i asked though just to see lol
i mean honestly though have we ever seen anyone break a stock piston outside of severe det?
Old Nov 4, 2013 | 02:00 PM
the3kgt2's Avatar
the3kgt2
I think that's just poor wording too. It sounds like he used the factory crank, but the rest of it is from the very first time he built the car. There's an "and" between crank and pistons, but elsewhere he uses commas to separate.
Pistons, rods, heads, cams and turbos (from the very first times that we ran the Infiniti) and factory crank.
Old Nov 4, 2013 | 03:01 PM
jerryd87's Avatar
jerryd87
*shrug* see if they answer since thats the only way we will know for sure, with two ands in the sentance it seems to me they used a comma instead of a semi colon. there is definitely a type somewhere its either a semi colon or the second and in the sentence
even if they are most people will still need aftermarket for any significant amount unless they intend to run large amounts of meth or run e85
Old Nov 5, 2013 | 06:10 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Regardless, I'm glad to see a 6 second G35.
Link and/or more info about this turbo setup? What trans are they using?
Old Nov 5, 2013 | 07:55 AM
jerryd87's Avatar
jerryd87
havnt seen any specs on them they apparently use two different turbo setups depending if they are running a 3.5L or 4.0L and i saw something somewhere they where running a powerglide.
https://www.facebook.com/ScottPorterRacing
Old Nov 5, 2013 | 08:00 AM
jerryd87's Avatar
jerryd87
actually take that back in the same post i quoted from they commented they use a lenco transmission, so much for everyones "all the fastest people run automatics" lol
Old Nov 6, 2013 | 04:07 PM
Resmarted's Avatar
Resmarted
Yeah factory crank, the pistons and rods and stuff must be from the first build.
Still scott porter is someone to look up to for us street car guys lol. Wonder what rods/pistons and sleeves.... I thought I read somewhere that they pushed the oem blocks to the six second range before then switched to billet blocks, but I'm not sure if they had sleeves put in (really assuming yes)
Old Nov 6, 2013 | 04:37 PM
OldManZ350's Avatar
OldManZ350
Rods are an Aluminum Titanium Alloy 7078-T51/Grade 26H cut from billet.
Old Nov 6, 2013 | 06:32 PM
meatbag's Avatar
meatbag
Liberty trans
