Vortech V3 tuner kit dyno fuel problem-please help!
Old Dec 22, 2013 | 01:49 PM
beezbo's Avatar
beezbo
Originally Posted by OldManZ350
If you keep Adding Fuel Up Top, and it is still leaning out, then you do not have enough Fuel Supply…….
Not to confuse you, but with the Vortech supplied Aux Fuel Pump and FMU, 440cc injectors will work with the 3.12 pulley, because of the High fuel Pressure.
I'm not necessarily confused, I was just under the impression that a Walbro 255 would suffice for my set-up with no RFS and 440cc's. (Sentry's FAQ on Vortech superchargers) https://my350z.com/forum/forced-indu...questions.html
Old Dec 23, 2013 | 11:15 AM
str8dum1's Avatar
str8dum1
the pump is fine. without a RFS, you drop your fuel pressure by the same amount you are boosting.
So if you start with 50psi at idle and make 12psi of boost, your fuel pressure might be as low at 38psi at WOT. So not only do you have too small injectors you now also have inadequate fuel pressure.
Old Dec 23, 2013 | 12:52 PM
beezbo's Avatar
beezbo
Ok I see, in your opinion what should I do from here? Man, I relied waaaay to much on the search function on other people's similar set up to mine and it's biting me in the butt.
Old Dec 23, 2013 | 12:55 PM
beezbo's Avatar
beezbo
Btw, I found my dyno sheet and I guess it's a DYNOmite?
File Type: pdf
Old Dec 23, 2013 | 03:27 PM
str8dum1's Avatar
str8dum1
just get a set of 600cc injectors. you can sell yours to offset most of the cost
Old Dec 25, 2013 | 08:15 AM
beezbo's Avatar
beezbo
Sounds good I'll order some DW 600's and post up new dyno #'s soon. This might be a dumb question and it's unrelated, but if I adjust my bypass valve before my next tune to 6 threads instead of 10 showing will I need a re-tune because I would be building boost sooner?
Old Dec 25, 2013 | 04:29 PM
OldManZ350's Avatar
OldManZ350
NO! Leave the Factory Setting alone.
It's set to close around 10 in Vac.
Why change it?
Old Dec 26, 2013 | 05:13 AM
beezbo's Avatar
beezbo
A lot of people have stated that 6-7 threads showing on the Vortech bypass valve would be as follows. (Instead of the factory 10 threads showing). I figured it was best asking and not assuming anything. I like my sleep at night haha.
"The stock setting doesn't allow the valve to close (ie allow you to start boosting) until you're around zero vacuum. set the screw so that only 6-7 screws are showing and you'll start building boost a little sooner."
Old Feb 1, 2014 | 11:45 AM
beezbo's Avatar
beezbo
Default *Update*
Welp, I installed some DW600cc's and have the DW440cc's I removed for sale in the marketplace. Got it dyno tuned a couple of days ago at Element Racing here in Utah again with the same tuner as before. I didn't come close to my goal of 400whp, but to say I have a legit car with 400bhp+ isn't bad either . The weather sucks outside, so I have not taken her out for a joy ride just yet. Thoughts are appreciated.
Attached Thumbnails Vortech V3 tuner kit dyno fuel problem-please help!-20140129_191453.jpg
Old Sep 6, 2014 | 03:28 PM
NAbuilderZ33's Avatar
NAbuilderZ33
Sorry to wake the dead on this post, but i was also having the same issue with my build, ended up getting 332whp off of my 3.12 pulley. had 500cc injectors and walbro fuel pump and yielded the same results as you, OP. I picked up some 720cc Injectors today hoping to retune soon, also bought the GTM Pulley Set to help eliminate some belt slip cause i wan also only making 5.5 psi on the dyno. =/
Attached Thumbnails Vortech V3 tuner kit dyno fuel problem-please help!-dynosheet.jpg
NissanZcrazy
Nov 2, 2015 06:03 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
mcduck
Apr 27, 2004 06:33 AM
