DE build parts list
Old Jan 15, 2014 | 03:16 AM
evilscorp's Avatar
evilscorp
Default DE build parts list
Hey guys, got bored of 360whp from my vortexh v3 Sci, so I am planning on building my block and a few other things to up the power safely.
Items on car:
Gt maf
Walbro 255pump
Detchwerks 600cc injectors
aam stage 0 fuel return.
Stillen oil pan
One step colder plugs
AMS pulleys
Plenum spacer
Decats
Dc sports exhaust.
V3 SCI at 8psi.
The suspension brakes etc have all been done and other mods that don't matter, just interested in the engine.
So I have bought acl bearings and eagle rods, 3"charge pipe, comp clutch stage4 but need help on the rest!
What I plan on buying:
Arp head bolts
HR head gasket?
Modify the block to improve cooling and make use of the HR gasket,(drill new water ways or something, seen it on an online magazine about a drift car vq35 DE build.)
Fluidampr crank pulley.
3.12 vortech pulley(should max out the blower rpm)
Pistons???9.8:1 or 10:1?
Piston rings???
DC sports headers
Lightweight flywheel
Rev-up oil pump.
Balance the bottom end from flywheel to crank pulley
Hone block.
Uprev(again)
Leaving the heads alone bar cleaning.
Anything I've missed/suggestions for pistons?
And no I don't want to swap the blower for t-trim etc, going to see what is possible with mine.
Cheers for any help =)
Old Jan 15, 2014 | 03:33 AM
tcode's Avatar
tcode
How did you bought bearings? Motor is already apart?
Old Jan 15, 2014 | 04:19 AM
evilscorp's Avatar
evilscorp
No got them for a stupid low price so went and dived right in. They are standard size so if the crank is worn I will need to find a new one. The engine has done 56k miles.
Old Jan 15, 2014 | 12:26 PM
str8dum1's Avatar
str8dum1
go with 11:1 compression ratio. 1000cc injectors
Old Jan 15, 2014 | 12:48 PM
evilscorp's Avatar
evilscorp
What whp will 600cc run out at? I get 98Ron fuel here in the UK but 11:1 will probably be too high? Don't plan on running water/meth.
Old Jan 15, 2014 | 12:58 PM
the3kgt2's Avatar
the3kgt2
I would think 98RON (about 93 AKI) might be too low for 11:1 without having to worry about detonation. I'm on 9.5:1 with 91 AKI and have to pull timing to avoid pinging.
600cc's might get you to 450whp before maxing out. Depends on the rest of your fuel setup.
Old Jan 15, 2014 | 05:23 PM
Jaxter's Avatar
Jaxter
Look into the Si impeller upgrade for the Vortech. Or else be willing to overspin the SCi. The upgrade is under $400.
Old Jan 15, 2014 | 09:57 PM
evilscorp's Avatar
evilscorp
It might be $400 in the US but there isn't a vortech dealer/tech here in the UK so not an option as I don't trust/plan on sending the unit through the post back overseas, would take months and cost a lot. Also as stated I want to see what the SCi is capable of as everyone jumps up impeller or housing without trying to push the standard one.
As for fuel system see above, it's sitting around 41psi If I remember correctly.
Yeah I thought something around 9.8:1 or 10:1 would be best for the fuel I get here, (can also get 99Ron if I try).
Old Jan 16, 2014 | 02:27 AM
bealljk's Avatar
bealljk
+1 to the lower compression pistons and larger injectors…
with the procharger kit, making 13psi with the DW600cc injectors I made 455whp and both the injectors and blower were reaching their max outputs.
add an oil cooler - that's great that you are modifying your block, which will promote cooling of the block, but coolant only cools your block. oil, obviously lubricates, but also cools your internals…what's cooling your oil?
Old Jan 16, 2014 | 04:14 AM
evilscorp's Avatar
evilscorp
I might have a think about the injectors but I will probably go for 9.8:1 pistons (whatever's available)
Air is cooling my oil and here in Scotland it's always cold plus the extra capacity of the stillen pan will suffice, a few guys here actually find oil coolers are only worth while if it's a dedicated track toy(mine isn't) they have to block the fins as the oil won't reach temperature. But thanks for the suggestion.
Old Jan 16, 2014 | 09:02 AM
str8dum1's Avatar
str8dum1
ya stock is 9.8:1. I never had to pull timing out to 17psi on 93.
10:1 will probably be easiest to get off the shelf.
Old Jan 16, 2014 | 10:00 AM
OldManZ350's Avatar
OldManZ350
You did not pull out any timing @ 17psi on 93 octane????????
What?????
Stock is 10.3:1 by the way.
Old Jan 16, 2014 | 10:12 AM
thatv35guy's Avatar
thatv35guy
I made just over 500whp with my 600cc DW’s with no RFS, my car’s a turbo though.
Old Jan 16, 2014 | 12:10 PM
str8dum1's Avatar
str8dum1
I see what you mean, from stock timing..... obviously everyone has to pull timing from the stock map regardless of fuel is being run.
dunno where I got 9.8 from def no reason not to run 11:1 then
What?????
Old Aug 17, 2014 | 03:09 PM
CoobcioPL's Avatar
CoobcioPL
Stock VQ37VHR have C/R 11:1 and works very good after boosted.
On Supercharger You don't have to retard so much ignition like in turbocharged engines...
On normal europe fuel PB98 the C/R 11:1 and supercharged you have to retard igniotion 1* on 1psi.
So you plan to charge 11Psi you should take down 11* ignition
What boost do you plan, friend from Europe ??
Old Aug 17, 2014 | 03:34 PM
cashmoney03's Avatar
cashmoney03
I'd drop compression to 9.0:1 if running high boost. Then you could up the timing and still be safe. That or run 10:1 with water/meth. Boost and high compression aren't always the best of friends. Especially when running the blower at its max rpm. Air starts to get really hot even with an intercooler and hot air with high compression are just inviting detonation.
Old Aug 19, 2014 | 09:22 AM
evilscorp's Avatar
evilscorp
Forgot about this thread, well nearly have all my parts, went for custom wisco 9.5:1 pistons with the armour glide etc should arrive this week after many months waiting.
DC headers
Nismo thermostat
Timrod radius rod
3.12 pulley
Mishimoto hoses
3"charge pipe
L19 head studs
Arp main bolts
Rev up pump
So much other stuff
New bushes all round
Can't even remember it's all just been collected and thrown in the atic.
Just going to order the fluidampre pulley tonight and the head gaskets
Probably cometic as I can't be bothered with the hassle of machining the block for a hr gasket.
Think I should make about 14psi don't know don't care as it should be overkill with all the parts.
Now all I need is to build a bigger garage and buy a engine stand so I can start building, have had a few quotes for machining the block as the pistons are 0.02"oversized but still not sure if I will use the engine that is in the car at the moment which works or buy a spare one that has issues.
_bit
Oct 2, 2015 07:49 AM
