Belt hopping after installing GTM Pully mod on Vortech v3. Need some advice
Old Mar 13, 2014 | 07:53 AM
stevo_ef91's Avatar
stevo_ef91
Default Belt hopping after installing GTM Pully mod on Vortech v3. Need some advice
Yesterday we installed the GTM pulley mod with all supplied parts (minus the bolt as we didn't have a tap for it).
My car is using the revised belt set up.
we had to grind down the cam cover but it is still rubbing just a little bit.
on the first start the belt was slapping the **** out of the blower pulley..
we ground more of the cam cover down and tightened the crap out of the belt.
the slapping went away but there was still a sound coming from the belt whenever the letters hit the vortech pulley.
I drove home 1 hour yesterday with no problems.
I drive to work this morning and the belt has come off the edge of the vortech pully and is slapping again.
any ideas why this is happening?
https://www.youtube.com/watch?v=BOCe...ature=youtu.be
Pictures attached as well.
Attached Thumbnails Belt hopping after installing GTM Pully mod on Vortech v3.  Need some advice-20140312_155815.jpg   Belt hopping after installing GTM Pully mod on Vortech v3.  Need some advice-20140312_144837.jpg   Belt hopping after installing GTM Pully mod on Vortech v3.  Need some advice-20140312_135915_hdr.jpg
Old Mar 13, 2014 | 09:12 AM
350z006's Avatar
350z006
This may be a stupid question...but is the belt properly aligned with the other ribbed pulleys? (ie crank, alternator, power steering)
Old Mar 13, 2014 | 10:30 AM
stevo_ef91's Avatar
stevo_ef91
yes everything was ligned up and i drove the car everything was fine yesterday.
then this morning its hopped off the edge of the SC pulley.
im wondering if the belt is bad or maybe we put the GTM pully too close to the SC pulley.
Old Mar 13, 2014 | 01:23 PM
350z006's Avatar
350z006
Well, I would take off the GTM pully and re-install everything and see if the belt still hops, to isolate if the GTM pulley is the cause...
Old Mar 13, 2014 | 03:14 PM
Staisman's Avatar
Staisman
I have this mode and GTM pulley Installed exactly like on your picture. Never had any problems.
Old Mar 13, 2014 | 06:53 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Did you really need a gtm pulley for 3.12? I think my blower comes with a 3.33 or 3.12 but didn't think that I would have belt slip
Old Mar 13, 2014 | 07:27 PM
stevo_ef91's Avatar
stevo_ef91
That's the 2.87 pulley. I tuned at 11lbs with belt slippage.
I think we put the pulley to close to the vortech pulley. Moved it over to the left about an inch and put on a brand new belt the other one was already very chewed up.
Problem is fixed.
Dymsi
Sep 29, 2015 11:32 AM
