WTF?! Vortech Question
Old Mar 24, 2014 | 04:06 PM
tukeeg35's Avatar
tukeeg35
Default WTF?! Vortech Question
So im busy installing my V3 kit, and I get the mounting plate all set up and I attach the blower and I go to install it on my car and I realize the blower isnt oriented properly.
http://imgur.com/a/zfkdQ
That album has the necessary pictures.
So my question is, can i loosen the 6 allen head bolts holding the blower together and rotate it so that it faces the correct direction? Should I drain the oil out of it first? Are there any gasket issues I should be worried about?
I got the kit on here and the seller never mentioned anything being wrong with it
Thanks for reading lol....
Old Mar 24, 2014 | 04:45 PM
350z006's Avatar
350z006
You need to loosen the bolts in the pic below that hold the hardware that fastens the volute in place. No need to drain anything. DO NOT remove the gear cover.
Old Mar 24, 2014 | 04:53 PM
tukeeg35's Avatar
tukeeg35
Alright cool thanks man, just lay it on its face, loosen those bolts, and rotate it to the correct orientation and then re-tighten it? Any recommended torque specs for those bolts?
Thanks for your help
Old Mar 24, 2014 | 05:11 PM
350z006's Avatar
350z006
Basically; I don't know what the formal torque spec is; hand tight should be sufficient, but you can loctite them to be **** safe.
Old Mar 24, 2014 | 07:03 PM
phunk2's Avatar
phunk2
use a sharpie to mark the clocking of the bolts before you loosen them. When tightening, go back to the same point and you will be very close on torque. Perhaps go a degree or two further if you wish.
Old Mar 29, 2014 | 12:56 PM
tukeeg35's Avatar
tukeeg35
I'm having a little trouble getting the volute lined up correctly to properly mate up with the discharge pipe.
Could someone please take a picture looking directly down onto the blower so I can try and get it lined up correctly? I'd really appreciate it!
Thanks
Old Mar 31, 2014 | 07:44 AM
str8dum1's Avatar
str8dum1
when in doubt use a longer piece of silicone hose
Rev_Night
Nov 7, 2020 06:00 PM
issyz
Jul 2, 2017 03:04 PM
