More rear end grip on boosted cars?
Old Jun 26, 2014 | 12:00 PM
Z1NONLY's Avatar
Z1NONLY
I have a Quaife LSD and it's great, but if you are already laying rubber with both tires, a Quaife isn't going to help much.
I have driven a lot of Z's with worn out stock VLSD's. Those cars will benefit from a switch, but primarily because they are comparing non-working LSD to working LSD.
The most powerful 350 I have driven was an APS TT with ~600 whp. Not even 315 NT-01's and a clutch-type LSD could put all the power down on course.
Old Jun 26, 2014 | 08:15 PM
rcdash's Avatar
rcdash
Traction will be dictated by tires, contact patch (camber), and weight over the rear wheels. To get to zero or near zero camber, I believe you will need SPL midlinks and toe rods with eccentric bolt delete.
Old Jun 27, 2014 | 05:51 AM
JCat's Avatar
JCat
Old Jun 29, 2014 | 01:09 AM
jerryd87's Avatar
jerryd87
the top three ways to get more traction is increase the sidewall, get a softer tire, and suspension setup. more sidewall is how outlaw cars hook with over 2000 whp with only a 275 drag radial and the best bet for traction in a IRS car. Another way is SPL bushing to limit deflection of the wheels but the cars going to be less comfortable being a solid suspension. deflection from bushings will make the tires act like a spring and kill traction. dropping down to a 17 inch wheel with the same height tire will give you the best traction.
Old Jul 1, 2014 | 09:59 AM
Alberto's Avatar
Alberto
Cranky FI Owner
If its warm out I can hook 605hp/540tq in second gear.
295 KDW2 and -1.1 camber. Going from -2 to this setup made a massive difference straight line but also hindered the cornering slightly. I also run a 3.3FD though.
Best thing to learn how to be really good at is just peddle the car.
Old Jul 11, 2014 | 04:15 PM
NAbuilderZ33's Avatar
NAbuilderZ33
+1 Couldn't agree more...
Old Jul 16, 2014 | 06:17 AM
binder's Avatar
binder
This is the only way to get low camber. I have everything upgraded in the rear except the mid links (which require changing to a coil over setup as well) and the most I can get is -1.2* camber. If I try to take out more the toe gets way out of spec. So I was limited to that camber. I would like to run mine 0 camber but the cost of the midlinks and going to a coil over setup to fit them was around 2 grand. For the amount I drive the car it isn't worth the cost.
Yes
This as well.
I'm running considerably more power but when I was s/c at just around 500hp the M/T drag radials 305/35/18 hooked dead solid. I also have falken 452 275 wide tires for street tires and they are garbage. I could light them up in first gear before my car was boosted.
As for non-drag tires I think the recommendations of others that use street based tires would probably be the best choices. I have no experience with those tires but others say they get good results.
Mw870
Sep 10, 2015 07:50 PM
PureR3d
Sep 10, 2015 06:23 PM
Beater350z
Sep 9, 2015 03:36 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
ddegrande21
Sep 6, 2015 11:15 AM
