Compression ratio with 600+hp
Old Nov 1, 2014 | 10:06 AM
Omnimous's Avatar
Omnimous
Default Compression ratio with 600+hp
Any one running higher than 8:5:1 or 8:8:1 at these power levels?
Old Nov 1, 2014 | 10:53 AM
350z006's Avatar
350z006
I have 9.5:1 comp on my setup on my >600whp setup...but its a supercharger setup...
Old Nov 1, 2014 | 11:02 AM
2bad240's Avatar
2bad240
I plan to make close to 600 once I up the boost im supercharged and 11:1. Making 400 now on 7psi pulley. Getting a frs and changing to 14psi pulleys
Old Nov 1, 2014 | 11:04 AM
350z006's Avatar
350z006
LMK if you're interested in the pulley I used to get >600whp, I'm selling it in the marketplace...
Old Nov 1, 2014 | 01:42 PM
Omnimous's Avatar
Omnimous
Any TT setups?
Old Nov 1, 2014 | 01:48 PM
str8dum1's Avatar
str8dum1
it all depends on your fuel.
Since I run E85, on my rebuild I'm going from my 9:1 to at least 10.5:1
I've done >700whp on 93 with my 9:1
Old Nov 1, 2014 | 02:02 PM
Omnimous's Avatar
Omnimous
It will be mostly pump gas at 94 octane. Any detonation issues?
Old Nov 1, 2014 | 08:21 PM
blue350zed's Avatar
blue350zed
9.1:1 on 93 octane, 15psi 650whp and no issues for two years...knock on wood.
Old Nov 30, 2014 | 02:13 PM
Brolan04z's Avatar
Brolan04z
Blue350zed what size turbos do you have that you are making that much on 15psi?
Old Nov 30, 2014 | 03:44 PM
padilla03z's Avatar
padilla03z
^ he has a build thread u can look at
Old Dec 1, 2014 | 07:14 AM
tcode's Avatar
tcode
According to his signature 3.8l HR stroker.
Old Dec 1, 2014 | 10:14 AM
phunk2's Avatar
phunk2
11:1 all stock engine for me (e85 671rwhp).
i am building a 10:1 engine to swap in with larger turbos. sort of wish I would have done more like 10.5:1 but at least with 10:1 I can still push the engine a bit on normal gas if E85 becomes unavailable in the future.
etkms
Jun 19, 2022 06:30 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Shane86
Sep 17, 2015 05:33 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
