NGK spark plug gap?
Old Feb 6, 2004 | 02:13 PM
mprowe350's Avatar
mprowe350
Default NGK spark plug gap?
I have my NGK spark plugs (that ATI recommends) and would like to gap them properly. I am running 8 pounds of boost and currnetly have them gapped around 38-40. What is the gap that some of you others are using? ATI told me 25-30 is that correct?
Thanks,
Mike
Old Feb 6, 2004 | 02:22 PM
elektrik_juggernaut's Avatar
elektrik_juggernaut
.035 is what they recommend for high boost and off-road applications in the installation manual
Old Feb 6, 2004 | 02:27 PM
mprowe350's Avatar
mprowe350
Yeah I read that part in the instruction book, but after speaking with ATI they said to gap at 25-30. Are there any advantages/disadvantages?
Old Feb 6, 2004 | 03:22 PM
etx's Avatar
etx
I run .03 on all my turbo cars with copper ngk's. .03 is good for a lot of boost. If the boost blows the spark out gap em' a little shorter.
What is the part number of the plug? Is it stock heat range or colder?
Old Feb 6, 2004 | 03:42 PM
12SecZ's Avatar
12SecZ
Mine are at 37 and seem to like it, some went 35 others went 39 so I went right in the middle and it idles real well.
Old Feb 7, 2004 | 03:32 AM
mprowe350's Avatar
mprowe350
30 sounds good since i'm about 39 right now and the dyno graphs show some minor spark blow out. I would like to see some more numbers from others if possible because pulling these plugs and changing the gap isn't my favorite thing to do. Hopefully i will get it correct this time.
Old Feb 7, 2004 | 03:33 AM
mprowe350's Avatar
mprowe350
sorry it is a colder plug(one range cooler)
Old Feb 10, 2004 | 01:07 PM
350z_taquito's Avatar
350z_taquito
depends on how much boost you're running.
Old Mar 7, 2005 | 04:08 AM
zcar03's Avatar
zcar03
I will be running 9psi on my ATI with 1 step iridium NGKs...What should I gap at?
Old Mar 7, 2005 | 04:43 AM
one3502nv's Avatar
one3502nv
We are gapping them around 32 with our forced induction cars...
Old Mar 7, 2005 | 07:49 AM
phunk's Avatar
phunk
CJ Motorsports
<--- 467rwhp stock original spark plugs at stock gap.
Old Mar 7, 2005 | 08:05 AM
one3502nv's Avatar
one3502nv
I know you guys know what you are doing but I would at least check your plugs... when I pulled out my stock plugs, they were gapped anywhere from 40-52!!! Not good....
burglapfd
Dec 6, 2020 01:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
