AFR not changing
Old Dec 21, 2014 | 09:12 PM
turboed350z's Avatar
turboed350z
Default AFR not changing
Ok so i have a serious problem. I have a wide band sensor and during normal cruising the guage reads 14.6/7. Which i believe is fine. The problem is, when im on boost, it STILLS reads 14.6/7. Any suggestions?
Old Dec 21, 2014 | 10:00 PM
phunk2's Avatar
phunk2
bad gauge/sensor or bad tune.
Old Dec 22, 2014 | 04:11 AM
turboed350z
So when i turn the car on without starting it, the gauge still reads 14.7. Could that be a tune issue? Im lean towards gauge/sensor problem
Old Dec 22, 2014 | 04:13 AM
jdm-v35's Avatar
jdm-v35
yea sounds like bad sensor or disconnected sensor/wire. Had that exact same problem with my AEM eugo this weekend. was working under the dash and pulled the wire by accident and pulled plug out of the gauge. plugged back in and it worked. it will probably fluctuate more than .1 even if the tune is bad.
Old Dec 22, 2014 | 04:18 AM
taywan's Avatar
taywan
Is it an aem wb? If so, those seem to be pretty notorious for issues.
Old Dec 22, 2014 | 05:17 AM
turboed350z
That id the exact one haha. So its just a sensor/connectiob issue?
Old Dec 22, 2014 | 05:18 AM
turboed350z
Thanks for the help. I was skeptical that it was a bad tune since everything else is on point. Wikl have to trace the problem down this weekend
Old Dec 22, 2014 | 05:26 AM
taywan's Avatar
taywan
Just get an innovate wb. Mine has been working fine. Only thing you should have to swap is o2 sensors every once a while.
Old Dec 22, 2014 | 06:28 AM
turboed350z
How often is "every once in awhile"? Last time i heard that it was once a month haha
Old Dec 22, 2014 | 06:29 AM
taywan's Avatar
taywan
I've had mine for a couple years and only had to swap out 1.
Old Dec 22, 2014 | 06:53 AM
turboed350z
Sounds easy. Qyick question, wherr did you install your o2 sensor, i read that posisition matters on accuracy and longevity. Did you placed it pre cat or post cat?
Old Dec 22, 2014 | 07:56 AM
taywan's Avatar
taywan
I don't have any cats on mine. It's on the downpipe on my kit..pretty much about under the clutch area, easiest way to explain.
Old Dec 22, 2014 | 08:07 AM
turboed350z
I dont have cats either haha mines on the passenger side for the down pipe. Is it possible i can buy any brand 02 sensor or does it have to be aem?
Old Dec 22, 2014 | 08:10 AM
thatv35guy's Avatar
thatv35guy
I thought AEM just used a Bosch LSU 4.2 sensor
Old Dec 22, 2014 | 08:23 AM
meanz's Avatar
meanz
I've had issues with my aem also, even sent it in and to get fixed, ended up being a bad unit, now I'm still having issues again after being replaced.
Old Dec 22, 2014 | 08:24 AM
turboed350z
I might have to check on that. Cause like taywan said, the aem are notorious for failed sensor yet bosch has good review?
Old Dec 22, 2014 | 08:51 AM
jdm-v35's Avatar
jdm-v35
the AEM does use a Bosch sensor. seems to be working great for me so far. the closer upstream you have the sensor, the more accurate. precat of course. If you mount it upside down (in relation to the ground) it will affect longevity as unburnt fuel or water vapors collected at the bottom of the pipe can damage the sensor. I would check your connections to the sensor first. if there is no wiring issue it could be the sensor or even the gauge.
Old Dec 22, 2014 | 09:12 AM
turboed350z
Thats for the info and the advice. I would most definitely check the sensor and wiring first. Hoping that its n9t the gauge itself. Thats going to be a pain...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
