TimRod StructRod ***Vortech***
Old Jan 16, 2015 | 03:45 AM
aboodi's Avatar
aboodi
Default TimRod StructRod ***Vortech***
Hello Guys,,
as you know guys i made 550whp with the smallest vortech v2 supercharger.
the thread is here :
https://my350z.com/forum/forced-indu...oday-dyno.html
to make power you need number 1 : solve the belt issue to get maximum boost without too much belt tension which can lead to bearing failures in pulleys or in jackshaft.
before i get the structrod from TimRod.. i was getting the belt tight every week and finally the belt became bigger and i can not get it tight anymore.
i tried the structrod with 10 psi.. i was surprised with the result.. very smooth psi entire rpm. then when i decided to make 17 psi.. its was so smooth .. i got it so easy.
what happen is in high rpm and the supercharger plate flex toward the crank and the belt become lose and make belt slip..
The timrod structrod simply keep the plate in its position then you will get smooth increasing psi entire rpm until redline.
the structrod in the pictures below:
i worked in my car by my hands and i tuned it myself.. with smooth PSI I made 550whp. i seen many belt issues,, and without timrod structrod i will switch to turbo.. but now i'm so happy with my power.
Good luck guys making big power with vortech..
Old Jan 19, 2015 | 09:42 AM
Z33Garage's Avatar
Z33Garage
I have been reading the Vortech thread for years. I honestly cant wait to finally get mine at some point and install it.
"On the next episode of Z33Garage... "
Old Jan 19, 2015 | 09:49 AM
aboodi's Avatar
aboodi
send message to oldmanz350
he is timrod..
Old Feb 7, 2015 | 08:47 AM
kbailey91's Avatar
kbailey91
I just wanted to throw in my 2 cents here also. I have an 03 non rev up with the V3Sci blower. Before the strutrod i was only making 9lbs and 458whp/390ftlbs with the 2.62 pulley and the 34/28 cogs and stock crank pulley. I throw on the strut rod and then re tuned. after doing this the belt slip was fixed and i made 13lbs with same gearing setup, 503.5whp and 435ftlbs - i would also contemplating switching to turbo, but with these numbers i am super happy. thanks again oldman!
Old Feb 7, 2015 | 10:49 AM
NAbuilderZ33's Avatar
NAbuilderZ33
Nice Numbers!
Old Feb 7, 2015 | 11:05 AM
meanz's Avatar
meanz
Great results! Mind posting a pic of your belt layout?
Old Feb 7, 2015 | 11:20 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
^hes got a revup motor which will have a super long belt and horrible layout
Old Feb 7, 2015 | 11:32 AM
meanz's Avatar
meanz
It says 03 non rev up... Not the op
Old Feb 9, 2015 | 07:34 AM
kbailey91's Avatar
kbailey91
Default here
i use the basic revised layout (no pulley mod I.E. GTM).. 78.5 inch belt
Old Dec 31, 2019 | 09:06 AM
OldManZ350's Avatar
OldManZ350
Seems that a lot of people out there are in need of a TimRod Radius Rod.
Please PM me If you have any questions, please do not ask questions in this thread. P.m. me
There are only two versions one for a 350Z and a G35
Old Jan 2, 2020 | 06:22 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
please get on fb and sell these again. some noob is selling a weak bracket for 180 bucks. fools are buying it because its the only option out right now.
Old Jan 3, 2020 | 01:06 PM
OldManZ350's Avatar
OldManZ350
That's Funny!
Old Jan 3, 2020 | 01:48 PM
bealljk's Avatar
bealljk
I definitely need one ...
Old Jan 6, 2020 | 12:07 PM
0taku's Avatar
0taku
Definitely gotta be careful for the higher boost crowd. I think I added too much tension on mine. After I reached 24psi@5800rpm , my belt snapped and my bracket got warped from the tension or force (I dunno which). So don’t over-tighten it.
Old Jan 6, 2020 | 01:17 PM
bealljk's Avatar
bealljk
with all due respect to the supercharger realm - I think there is only so far you can push them. I think if you want to big power (lets say over 600hp) you have to go turbo.
Old Jan 6, 2020 | 07:03 PM
OldManZ350's Avatar
OldManZ350
It is a challenge for sure, But I like Superchargers......... The Biggest hurdle is the 6 Rib Belt, the cost going to a 10 Rib is substantial.......
Colombo made well beyond 710WHP. And he went 167MPH in the Standing 1/2 Mile on 93 Pump Gas. (V2 Ti-Trim) @ 26psi, When he retuned on E85 it was over 800WHP
Aboodi has not been on a Dyno when completed. He is on E85 (V7 YSi-B) @ 32psi, But I'm sure High 800WHP
Old Jan 6, 2020 | 07:05 PM
OldManZ350's Avatar
OldManZ350
Did you have a Radius Rod?
Old Jan 6, 2020 | 09:21 PM
bealljk's Avatar
bealljk
I like them too, and I appreciate what you (and other members) have accomplished with them. Whats good for the goose is good for the ganders - I have nothing bad to say about them. I enjoyed my time with my procharger (455 on 14psi) but they are limited. I think you see more people go from a supercharger to a turbo because their limits.
very respectable numbers for these respected members and I'm not taking away anything either you, Colombo, or Aboodi - you all have accomplished quite a bit and it's well above what I've done. But these three examples are the tip of the spear for the super-charger realm. If you look at what the premier turbo'd members are/were putting down Colombo would be in the high teens and Aboodi at his 800hp would hypothetically put him 10th
https://my350z.com/forum/forced-indu...50-list-4.html
good stuff though, good content for sure.
Old Jan 6, 2020 | 09:30 PM
OldManZ350's Avatar
OldManZ350
Absolutely!
Turbos much easier to make power for sure!
Old Jan 7, 2020 | 04:46 AM
0taku's Avatar
0taku
That’s correct.
Right now I been waiting for my friend to have some free development time to get some prototypes for some 10 rib pulleys before I continue.
Rather give up and upsize to the 3.13, I planned on going smaller with a 10 rib. Although it’ll take time for him to be free. I can probably guess it won’t started until at least late 2020/ early 2021.
Im just staying S/C because it’s fun to attempt for higher power that hasn’t been done before. I dunno, maybe I’m just stupid chasing the dream and losing a lot of money in the process.
