selecting cams to match with sound performance tt kit
Old Feb 11, 2015 | 06:58 AM
  #41
juelz86z3303's Avatar
juelz86z3303
Originally Posted by ttg35fort
The Tomei's open the exhaust valve relatively early, resulting in a relatively short overlap at top dead center (at 0 deg. cam phasing), which means they should idle quite well. They won't scavenge that well, but scavenging isn't as important in a turbo motor as it is in a NA motor. In fact, on a turbo motor, if the back pressure is too high on the exhaust side, reversion can sometimes become an issue. This may be why Tomei has chosen to open the exhaust valve relatively early. I'm not sure why they are running lower lift on the exhaust than on the intake, though. Nonetheless, I think they will perform well.
That's crazy maybe they were thinking of boost. But I don't see why they would keep lift so reletivaly short.
Old Feb 11, 2015 | 09:44 AM
  #42
juelz86z3303
Originally Posted by Resmarted
I have eagle rods and weiseco pistons with the increase in piston gap and ring gap. Also wiseco upgraded wrist pins (for over 600hp). Dynosty basically told me mechanically the short block doesn't have a "rev limit". And realistically it shouldn't with the girdle and the light eagles. The oil pump on the other hand doesn't quite work that way. But 8.5k is totally do able on my setup.
Again I'd recommend the BC stage 3's over tomei. Tomei has that cool factor, but they're also rb26 specialists... Not really vq35 specialists. I'd be interested to look at the tomei cam card info. The BC stuff comes in any form you want, like turbo or NA spec.
There are two mods that come to mind if you want to go high rpm and do something different. I'd get a nismo intake cam gear, it has more advance than the stock one, quite a bit more, so you should be able to find a bit more power up top. And second is the nismo oil pump, or a machined rev up pump. If you do some searching theres a good thread on here talking about what causes our oil pumps to fail (non HR oil pumps). Machining isn't very hard to do if you have a good machinist, I wish I had thought of that before hand, but I'll probably take my car out to 8500 on occasion anyway.
OK so you didn't mod your revup oil pump Resmart ?
If I remember correctly is has something to do with the De gears In oil pump and crank vibrations. And our de motor oil pump wasn't design for high output far as rpm.
that all I remember and what you stated about machining material off rev up pump for 8 percent flow. quote me if I'm wrong not saying I'm right but that's all I remembered from when i read it. Lol 😎
Old Feb 11, 2015 | 11:51 AM
  #43
Resmarted's Avatar
Resmarted
Vibrations=bad. The rev up gear is a stronger material.
The machining is to done at the corners of the gear where the angle is sharp. You just want to open it up to reduce point loading at the corner, which is the weakest point of the gear. That's the biggest difference between a rev up pump and a nismo pump. I believe someone was machining them on here and selling them. Or you could run a stock one and be happy with 8k lmao. It won't grenade on your first pass over 8k especially if you don't have a ton of power and don't hit the rev limit but...
Old Feb 11, 2015 | 01:45 PM
  #44
juelz86z3303
Lol but room to grow is always good I mean while I eat 8k you can obviously go to 8.5 worried free on ocassions. .
Yeah I think he was but I missed out.
I rather be safe than sorry and extra precaution is always good in this field of performance /power so safety first. Lol
Thanks Resmart your the illest 😆
Old Feb 11, 2015 | 03:10 PM
  #45
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by 2bad240
Nice idle.
Old Feb 11, 2015 | 07:01 PM
  #46
Resmarted's Avatar
Resmarted
By the time my car is all finished up I might head down there. I've got a few tricks up my sleeve I'm waiting to show off for the car. Nothing too crazy but yeah. I'm on the central coast so we're not THAT far apart.
Old Feb 11, 2015 | 07:10 PM
  #47
Resmarted's Avatar
Resmarted
So the BC stage 3's have 4 degrees less lift at .05" and seem to have much more overlap. But they have more peak lift. These cams have been proven time and time again on the fastest 350z's... So I really have full faith in them. I believe both the 1200whp DJ SP z33 that set the 6 speed record first ran them, then Hal/Dynosty's z33 used them to set the quicker 9.3 record with a 800whp DD setup.
http://www.briancrower.com/makes/nis...rd/bc_0222.pdf
Old Feb 12, 2015 | 07:22 PM
  #48
juelz86z3303
Idle vid
http://youtu.be/LpWPyWx7Htg
Daayum
That sounds bad a$$🏁🏁
Old Feb 12, 2015 | 09:05 PM
  #49
Resmarted's Avatar
Resmarted
Daayum
Lol my car shakes the pictures and windows inside the house on idle... Max out the mic like a ****. Gonna change things up real soon though so I'll have to get new vids once the new stuff is together.
Old Feb 13, 2015 | 05:24 AM
  #50
juelz86z3303
I love Hal's Z it inspired me to break the sound barrier
But yeah that's true what you saying and I witness it them both on YouTube lol
Old Feb 13, 2015 | 05:39 AM
  #51
juelz86z3303
Ohhh mang you needs to show me and stop holding out on them Z video's lol.
Resmart
Old Feb 13, 2015 | 06:25 PM
  #52
Resmarted's Avatar
Resmarted
Resmart
I figure when the car is completely driveable I can focus on getting video. When I'm checking for fuel leaks, trying to get the car running right in the garage (baby steps), last thing I care about is video. I did grab a few snapchats and sent to friends (who loved it) but those are long gone.
Old Feb 23, 2015 | 08:21 PM
  #53
juelz86z3303
[QUOTE=Resmarted;10547460]I figure when the car is completely driveable I can focus on getting video. When I'm checking for fuel leaks, trying to get the car running right in the garage (baby steps), last thing I care about is video. I did grab a few snapchats and sent to friends (who loved it) but those are long gone.[/QUOT
Yes sir and I ordered the bc 272"s and got the pump modified over going Nismo.
Thx again
Old Feb 23, 2015 | 08:47 PM
  #54
Resmarted's Avatar
Resmarted
[QUOTE=juelz86z3303;10552443]
Thx again
Good choice man, you'll be quite happy. Might want to have a shop press in the springs. My buddy who's 270 6'9" barely could get them in lol.
Old Feb 24, 2015 | 01:29 PM
  #55
juelz86z3303
[QUOTE=Resmarted;10552445]
Yeah they going to do the install for me. Im Just going to pick up the LB.
Also last is the vtc pulleys man gotta get em lol.
I'm going to add those with the jwt exhaust cam gears sprocket . Should go good.
Thanks for your help and every one who helped with their input.
Old Feb 24, 2015 | 01:43 PM
  #56
str8dum1's Avatar
str8dum1
you do know you gotta pull the engine apart if you wanna make changes with those JWT exhaust gears.
Hope your tuner has used them before and can do math.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
