Procharger Project (4 months of hell)
Old Feb 4, 2015 | 12:41 PM
OldManZ350's Avatar
OldManZ350
need to use motor oil on the o-ring when installing on injector and installing into intake.
Old Feb 4, 2015 | 01:37 PM
str8dum1's Avatar
str8dum1
also make sure they are 14mm, but ya like everything, you need to grease before insertion
Old Feb 4, 2015 | 02:49 PM
Conway_160's Avatar
Conway_160
Procharger Project (4 months of hell)-image_a07a1f878706869a4c6f8b8197f37e23ce256e02.jpg
I had the same problem you are having, I had to make a phone call and ask about the grommet.
Click on the picture, F you Microsoft paint!
Old Feb 4, 2015 | 03:46 PM
NeoGixxer's Avatar
NeoGixxer
Well guys, the car is fixed. On the pic above, the left injector was the corrected way.
It turns out the problem I was having was my fuel rails (Thank you JDM & Conway for the info to check that). The passenger side fuel rail wasnt sitting flush like it should. For some reason cylinder 1 injector would not completely sit flush in the block but all the remaining injectors did. Causing the huge leak I was having (Bogging out the car on acceralation and rough idle).
The fuel rails sit on 4 plastic washers (bolts go thru them and hold the whole rail and injectors down). So I took out the plastic washer by cylinder 1 and bolted down the fuel rail. All the injectors sat flush after that and the car runs great!
Im taking the Z to the dyno tommorrow for my tune with Church. Ill let u guys know my HP gains. Thank you again everybody for all your info!!! I apprecaite it
Old Feb 4, 2015 | 03:49 PM
NAbuilderZ33's Avatar
NAbuilderZ33
That's awesome, good luck with your tune!
Old Feb 4, 2015 | 05:15 PM
Conway_160's Avatar
Conway_160
Gratz dude sorry it took so long for you to get yours running. Wish we could have helped sooner.
Old Feb 4, 2015 | 06:03 PM
jdm-v35's Avatar
jdm-v35
glad you got it running. I figured it must be a simple problem or tune. installing the procharger wouldn't instantly make the car run like crap unless something was missed.
Old Feb 5, 2015 | 09:16 PM
NeoGixxer's Avatar
NeoGixxer
Dyno the car today:
370 hp
336 torque
9 psi
Hey do u guys recommend a good blowoff value for this setup?
Old Feb 6, 2015 | 03:47 AM
jdm-v35's Avatar
jdm-v35
not a blowoff. superchargers need a bypass valve which will open at idle and open under less vaccum or you may damage the supercharger.
Old Feb 6, 2015 | 04:03 AM
Conway_160's Avatar
Conway_160
You can use a bov it just has to have a 1psi spring or something that keeps it open at idle. I know the bov I have from procharger leaks when it closes.
Old Feb 6, 2015 | 09:32 AM
NAbuilderZ33
Originally Posted by NeoGixxer
Dyno the car today:
370 hp
336 torque
9 psi
Congrats! How does she feel on the road?
Old Feb 6, 2015 | 10:23 AM
NeoGixxer's Avatar
NeoGixxer
She's aggressive, you can easily spin the tires thru 1st and 2nd gears. Which I should stop doing cause the tires are brand new 😁
Old Feb 6, 2015 | 10:48 AM
NAbuilderZ33
Haha, that's great! Bet you had a blast after the tune. Its a great rewarding feeling when you finally see the fruits of your labor. All the hard work and determination definitly paid off.
Old Feb 6, 2015 | 12:16 PM
2bad240's Avatar
2bad240
I have tial q with supercharger spring. It's very loud though
Old Feb 6, 2015 | 12:31 PM
meanz's Avatar
meanz
Tial q 50mm is what a few of us are running on blower setups.
Old Feb 6, 2015 | 02:44 PM
str8dum1's Avatar
str8dum1
you must have a valve on your setup now? You just want a different noise?
Dyno the car today:
370 hp
336 torque
9 psi
Old Feb 6, 2015 | 05:58 PM
NeoGixxer's Avatar
NeoGixxer
I do, its a Apex something. I'm not to happy with it. I checked out the Tial q 50mm. A lot of people mentioned that it was extremely loud even while cruising.
I'm looking for something mellow while cruising but loud when I'm on the gas
Old Feb 7, 2015 | 03:38 PM
  #38
meanz's Avatar
meanz
When your on the gas, wot, the blow off valve is closed and not making any sound. I really don't mind it at all. I like it.
Old Feb 12, 2015 | 01:47 PM
  #39
str8dum1's Avatar
str8dum1
nothing will be mellow unless you recirculate. you are dumping all the air from the supercharger out the valve.
Old Feb 13, 2015 | 06:52 PM
  #40
Resmarted's Avatar
Resmarted
The only BOV's that are not as annoying are the ones that don't have the stupid edges and crap.
As str8 said, as long as your atmospherically dumping it will make noise. So the more rpm you put in, the more air you will dump, and the louder it will be.
But you could always try a synapse bov or a tial knock off. I have a 50mm tial knock off made by RPS. Works pretty well, esp for the price. They stand behind that BOV as well. Like the way it sounds on the cars I've seen withit.
