Crank case went to air
Old Jan 28, 2015 | 03:03 AM
aln's Avatar
aln
Default Crank case went to air
Hey,
Anyone vented their crankcase straight to air with two filters? (both sides) If so any pics, thoughts, sizes etc?
My tune isnt reading off the MAF so not to bothered about that.
Goal is to lower crank pressure.
Old Jan 28, 2015 | 06:10 AM
zach711f's Avatar
zach711f
I ran a hose from both valve covers to under neath the car to dump fumes.
Old Jan 28, 2015 | 10:32 AM
str8dum1's Avatar
str8dum1
almost everyone vents to air. doesnt matter if its thru a catch can or not.
i use 3/4" lines.
Old Feb 2, 2015 | 11:58 PM
aln's Avatar
aln
i use 3/4" lines.
cool, got two filters will vent them straight to air without catchcan.
Old Feb 3, 2015 | 11:24 AM
str8dum1's Avatar
str8dum1
jus FYI, the filters really collect the oil and drip onto whatever is below them. my frame rail is a mess
Old Feb 3, 2015 | 04:50 PM
Resmarted's Avatar
Resmarted
Lol so true.
If you use a check valve for catalytic converters (not sure where we found them) but you can use the vacuum of the ehxaust to suck out crank case evap. Definitely the cool way to do it. But with a vq you're gonna have to put it pretty far back to not foul up o2 sensors (vs a 2jz where every turbo aspect is better lmao)
Old Feb 4, 2015 | 06:22 AM
tcode's Avatar
tcode
Have you enlarged ID on valve cover pipes?
Old Feb 4, 2015 | 01:33 PM
str8dum1's Avatar
str8dum1
the covers are plastic, drill them out to whatver size you want. mine are -12AN
350z82
Oct 1, 2015 06:25 PM
