blow by issue
Old May 5, 2015 | 12:19 AM
aas350z's Avatar
aas350z
Default blow by issue
I have got serious problem with bylow by. Back pressure from crank case is huge. All retainers and seals are blow after 15 minutes’ ride on boost. I tried everything, currently I’m venting crank case directly to the atmosphere via all four holes in covers (drivers side this from back, passenger side-drilled and this two from front of the engine). This doesn’t help. Anybody has similar problem ? I’m thinking about drilling hole directly in block or pan because I don’t have any other idea. Maybe somebody already tried it please share your experience.
My setup is build vq35de with greddy tt kit compression ratio 8:8.1 on CP pistons.
Old May 5, 2015 | 12:24 AM
tcode's Avatar
tcode
That massive blow by can't be good. Piston rings or ringlans must be shoot.
Old May 5, 2015 | 05:42 AM
aas350z's Avatar
aas350z
Compression on all cylinders is quite good. Engine works fine, I don’t think that rings are damage… for sure I need to vent crank case more efficient.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
