03 vortech build progress
Old May 31, 2015 | 07:13 PM
studbolt03's Avatar
studbolt03
Default 03 vortech build progress
So I have owned my Z for a long time and have never done much with engine besides intake and exhaust and test pipes ..always went from show to show and I keep it clean and it lives in a garage. I came across a deal on a new vortech kit for a REV Up motor. The deal was too good and I could not pass it up. So I started the build and I have to finish up a few things but here is the progress. It is possible to use a rev up bracket but you had to modify it and move pulleys around. But it did work. Anyways on to the pics and it goes to Dynosty on the 24th for uprev and tune.
Here she is before
Old nitrous bottle not for the build.
Vortech V3 kit uprev with 3.12 pulley
600 injectors
Dw200 fuel pump
Uprev gt MAF
Don't mind the zip tie temporary until I am done
So it still has to be finished up so don't mind loose ends but this is the progress so far. I ditched the fuel setup and unichip it came with because I also got injectors and pump with the kit. Can't wait to finish it!
Old May 31, 2015 | 07:38 PM
OldManZ350's Avatar
OldManZ350
Hose goes behind the Vortech Bracket. And may be different on the Revup? So what are your plans for the coolent hose?
Old May 31, 2015 | 08:03 PM
studbolt03's Avatar
studbolt03
There wasn't a groove for the coolant hose on rev up bracket. On instructions for rev up install it says to attach to cooling fan shroud. I don't like that idea. Just like I didn't like smashing power steering cooler against radiator so I made a nice bracket to attach it too. I forgot to post pic of that modification
Old May 31, 2015 | 08:45 PM
rustyschopshop's Avatar
rustyschopshop
Everything looks nice, gratz on the great buy. BTW you may want to replace that bypass hose, it looks like it is quite swollen. Would hate to see it burst on/off the dyno.
Old Jun 1, 2015 | 05:23 AM
OldManZ350's Avatar
OldManZ350
YA, thought it was something like that.
Old Jun 1, 2015 | 09:24 AM
studbolt03's Avatar
studbolt03
I just went to the part store this morning and ordered the coolant hose no problem thanks guys for all the input I really appreciate it !
Old Jun 1, 2015 | 09:27 AM
studbolt03's Avatar
studbolt03
What are your thoughts about bypassing the hose like when they do a wire tuck?
Old Jun 1, 2015 | 09:58 AM
2bad240's Avatar
2bad240
You can get the caps at any parts store I cap them off on most of the cars I work on.
You can see the cap on the pipe in this pic. Name:  487B113A-F324-431C-B303-FB868F81609A_zpsl23lnq8y.jpg
Old Jun 2, 2015 | 11:58 AM
studbolt03's Avatar
studbolt03
no issues with doing this? or do you think I should loosed the bracket and squeeze a new coolant behind the bracket?
Old Jun 2, 2015 | 12:00 PM
2bad240's Avatar
2bad240
No issues at all.
Old Jun 2, 2015 | 05:08 PM
Conway_160's Avatar
Conway_160
Man, I wanted to do this to the infiniti but didn't know what would happen if I capped off the lines. Stupid Coolant Line!
Old Jun 4, 2015 | 10:47 AM
studbolt03's Avatar
studbolt03
I purchased caps to block it all off. I take it no one has seen issues with it? is it ok for street driving and track or? I also purchased the 1 piece intake pipe versus the 3 from vortech. looks a lot cleaner
Old Jun 5, 2015 | 06:54 PM
rustyschopshop
I have been running without the bypass for quite some time now, plus deleted and modified even more of the cooling system with more still to come.
Old Jun 6, 2015 | 12:21 AM
OldManZ350's Avatar
OldManZ350
Explain......
Old Jun 6, 2015 | 11:03 AM
ocdz's Avatar
ocdz
Just thought I would chime in on the coolant delete.
I have deleted the stock oil warmer and the coolant crossover on my car. I accomplished both by using hydraulic line hard caps (called yor-lok fittings on Mcmaster Carr). These are designed to cap oil hydraulic lines at 3000 PSI so they work well on low pressure coolant lines. Only caveat being that they are not removable, but they are a much better long term solution than rubber caps.
I also run Evans waterless in mine, but I have not seen any difference in operating temperature. I did have slightly more trouble burping the system even though I thought I had it mastered having done it four times.
Old Jun 6, 2015 | 08:59 PM
StevSam's Avatar
StevSam
Look great!! Really want to do the same soon!!
Old Jun 9, 2015 | 05:10 AM
studbolt03's Avatar
studbolt03
Little update ..I blocked off the bypass hose and installed the one piece pipe versus the 3 piece from vortech ..have to button up a few small thing but install is done and fuel pump has been modified. I have uprev and tune done on 24th at Dynosty. Wish me luck.
Old Jun 9, 2015 | 05:17 AM
2bad240's Avatar
2bad240
Looks good. Just got mine running last night
Old Jun 9, 2015 | 05:35 AM
studbolt03's Avatar
studbolt03
Thanks! I've got to polish up a few parts from scratches when installing but no big deal.
Old Jun 30, 2015 | 08:20 AM
studbolt03's Avatar
studbolt03
UPDATE. I went and got the car tuned at Dynosty in Kentucky. Those dudes are great and installed Uprev and a tune. keep in mind I have an uprev kit on a non uprev car..so boost is a little different with the cog pulley setup. Car made 375hp on 7pounds of boost.
