greddy tt kit question
Old Feb 11, 2004 | 07:18 AM
reanimation's Avatar
reanimation
Default greddy tt kit question
when installed, im looking to keep the boost at what greddy recommends.. something like 5.6lbs.. do i need to adjust my timing with such low boost.. and will the a/f ratio need ajusted as well? will i be able to just use the included e-manage fuel computer? or should i get like a techno square ecu too? as i said, i want to keep the boost pretty low
Old Feb 11, 2004 | 07:26 AM
aalzuhair's Avatar
aalzuhair
The kit comes as a Bolt-On, so I do not think you need to get anything else.
Old Feb 11, 2004 | 09:35 AM
g356gear's Avatar
g356gear
Timing control is always a good idea with FI on a high compression motor. Technosquare has a program for tt applications....called the Jotech program. You may want to add a blow-off valve to the kit to help reduce stress on the turbo impellers and bearings as well. Gauges would also be a good idea... boost,temp,egt,etc.
Old Feb 11, 2004 | 02:40 PM
reanimation
how about the air/fuel ratios? should those be altered? or can i just leave them as is at 5.6lbs of boost? if it does need to be altered, what product could do it for me?
Old Feb 11, 2004 | 02:48 PM
g356gear's Avatar
g356gear
If you want to stay with the pre-programmed e-manage that comes with the kit then you should be O.K with you're A/F ratios but they will be on the rich side. This is done because of the lack of timing control with the kit and they need the extra fuel to keep detonation down at 5.6 psi. If you wanted to alter it you could buy a Greddy Profec e-01 and then re-set (initialize) the e-manage and start tuning from the bottom up to make you're own maps. Just make sure you have someone do it who has a lot of experience with the e-manage/e-o1 combination. If this is the route you end up taking then you might as well add in the $40 ignition harness and do ignition maps as well.
my2cents
Old Feb 11, 2004 | 07:42 PM
shaun_walsh's Avatar
shaun_walsh
I have the TT kit and you just add it on to the car. the e-manage is solid. If you are going to higher boost then you would have to do other work.
shaun
Old Feb 11, 2004 | 08:03 PM
reanimation
is shaun accurate guys? will the e-manage take care of everything at 5.6psi?
Old Feb 11, 2004 | 08:07 PM
phunk's Avatar
phunk
CJ Motorsports
at that boost, i would imagine no problem. it wouldnt hurt to get your ECU remapped if your extremely concerned and dont mind paying the money.
Old Feb 11, 2004 | 09:19 PM
AgentOrange's Avatar
AgentOrange
yea the emanage will take care of everything.....but if your going to higher boost then you will need to start from scratch
Old Feb 11, 2004 | 11:59 PM
I-Speed GC8's Avatar
I-Speed GC8
Does anyone run the technosquare ECU reflash instead of the emanage? I did some searching and havent really found much about after market forced induction managed by a ECU reflash. Any answers would be appreciated.
As for management with higher boost applications, I hope the emanage suppiled by Greddy at least has a basemap if not tuned for the boost settings on the wastegate already. Its pretty basic to control the level of boost you want to run. The top banjo fitting on the Tial/Greddy wastegate is where you would hook up a boost line to a EBC or MBC. You can control your boost that way but you are going to need to tune on top of the map already loaded into the emanage. Also with more boost the timing is needs to be adjusted.
Andy
www.i-speedusa.com
Old Feb 12, 2004 | 10:31 AM
wu350Z's Avatar
wu350Z
i think as long as you dont adjust your boost any higher then what greddy recommanded then you should be ok
Old Feb 12, 2004 | 11:26 AM
etx's Avatar
etx
I believe the manual that comes with the IC kit says with the IC you can run .6 bar. So .6 bar = 8.702264 psi.
Old Feb 12, 2004 | 02:40 PM
fernandito7's Avatar
fernandito7
REally etx? Is that true?
Old Feb 13, 2004 | 02:19 AM
ACP's Avatar
ACP
my2cents
Hey g356gear
The GReddy TT kit comes with the ignition harness with the e-mangement...
Old Feb 13, 2004 | 02:41 AM
ACP's Avatar
ACP
wait, comes with Injector Harness not ignition harness
that is what I get for answering so early in the morning, without coffee
Old Feb 13, 2004 | 08:10 AM
rescube's Avatar
rescube
Question Greddy T/T kit....intercooler?
Hi, I would like to know is it require to remove the front protected bar from installing the Greddy Intercooler?And If I install the intercooler does it means I cant have the Protected bar anymore?
By the way, is the wastegate usefull in in 350hps Z? If not then I am planning to get PE t/t kit.
Which T/T will you guys choose interms of performance, best T/T kit parts, and reliable T/T kit?
Thank you..
Old Feb 13, 2004 | 10:15 AM
Jonn's Avatar
Jonn
Default Re: Greddy T/T kit....intercooler?
You can turn the boost on the greddy kit up to 8lbs with an intercooler. However the fuel mixture gets a little lean at high rpms.(13.5:1)
But this makes quite a bit of power 391 actual hp to the ground
If someone wanted to completely reprogram the e-manage I bet you could run about 10lbs.
Jon
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
