3.9 final gears along with stillen v3 set up ?
Old Sep 18, 2015 | 06:25 AM
Bodyboarder81's Avatar
Bodyboarder81
Default 3.9 final gears along with stillen v3 set up ?
Hi all ,
Firstly apologies if this is in the wrong section .
I have the stillen v3 kit on my HR 350z and running around the 400whp with the 9lb pulley .
One of my next mods will be the quaife diff . I am also considering the 3.9 final gears at the same time as the diff swop .
Does anyone run these gears with a charger ? ( I know big blue does ) do they work well with the added power from the charger ?
I don't 1/4 mile my car and not one for off the lights racing . I'm interested in acceleration say from 30-120 ..... Will running these gears be quicker than my standard ( 3.5? ) final gears ?
Any help would be greatly appreciated , especially from people with first hand experience with them .
Josh
Old Sep 18, 2015 | 06:50 AM
PP08HR's Avatar
PP08HR
Can we see some pics of said vehicle 1st.
Old Sep 18, 2015 | 06:51 AM
travlee's Avatar
travlee
Master
https://my350z.com/forum/new-owners/...-uk-owner.html
Old Sep 18, 2015 | 06:53 AM
PP08HR's Avatar
PP08HR
Ya know trav you really should use your power for the good of man kind!
Old Sep 18, 2015 | 07:05 AM
travlee's Avatar
travlee
Master
but that isnt as much fun!
Old Sep 18, 2015 | 08:10 AM
Bodyboarder81
Any excuse I pic *****
Old Sep 18, 2015 | 08:39 AM
PP08HR's Avatar
PP08HR
Nice!
As far as the gears go I have no idea. Only what I've read. lol GL
Old Sep 18, 2015 | 09:23 AM
BigBlue's Avatar
BigBlue
Nice pics of family and the car! I know that the 3.9 fd is right in my wheel house as far as I'm concerned; love it.
Old Sep 18, 2015 | 09:43 AM
Bodyboarder81
Have been doing a bit if reading and it looks as though you can still achieve over 60 in 2nd ( just ) and around 97 in 3rd .......
Decisions decisions
Anyone else you know of running them with FI ? I can see why you wouldn't want them if TT or big HP but for my application I can see the benefit ......
Old Sep 18, 2015 | 11:23 AM
iideadeyeii's Avatar
iideadeyeii
I have stock gears in my 03 6MT with only 300whp(fixing my tune for about 30hp more) and would like longer gears. 4th gear redlines at the end of the quarter and I rather not have another shift. /Shrug. Also 1st gear is pretty useless
Old Sep 18, 2015 | 03:58 PM
Boingo's Avatar
Boingo
Personal preference. I had the Central 20 3.9 final drive on the Z when I bought it. It is a single turbo, and I normally run a street tune map 450rwhp at 14psi. I did not like it, and bought a used 3.5 with LSD from local LKQ autoparts to replace it with. On average, the 3.9 runs the engine 300rpm more than the 3.5, so at highway cruising you are at 3300rpm most the time. The 3.9 made the car jump, as the torque delivery to wheel was higher earlier in each gear. Made it hard to ever hook up once boost hit - in 2nd, 3rd, and 4th. 1st gear was not much use. A good aftermarket 1.5 way LSD helps, then you spin both tires. Like some of the other turbo guys, I'm actually thinking of getting a 3.3 rear end from an automatic if one appears at LKQ (it was only $85, so great deal on complete rear end).
Old Sep 18, 2015 | 10:45 PM
Bodyboarder81
Ok all good info , and it confirms that they don't really work with turbo applications or higher ftlb cars ..... My power delivery is very linear and only run 360ftlb ( at the fly ) so I wouldn't have thought this would be an issue with jumping etc ......
Old Sep 19, 2015 | 12:37 AM
OldManZ350's Avatar
OldManZ350
Another Option is to get a larger diameter rear tire and/or raise the Rev Limiter 500RPM.
Old Sep 21, 2015 | 06:23 AM
iideadeyeii
As having one of the best stock engines/tune in the world you have no problem going over stock limiter and although my limiter is non-existent(Utec redline only works sometimes or maybe only at WOT...), I rather not go much higher than stock redline since my car makes less power and I just don't trust it enough.
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
davidm350
Oct 31, 2015 02:28 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
