Searching for new clutch set up. Need some input fellas
Old Feb 20, 2016 | 01:25 AM
  #41
350z-900whp's Avatar
350z-900whp
Originally Posted by rcdash
Look up post from XKR -> his ATS triple failed at far below the rated spec. Hopefully you have better luck. By all reports it does drive nicely though. He hated his OS Giken quad until he got the RJM clutch pedal.
Don't forget the SP racing drag car went into low 9s high 8 sec 1/4 mile , dyno run I think posted around 1100whp+ ( black 350z ) they where using rps triple. For some reason no one talk about it . I mentioned it just to refresh info
Old Feb 23, 2016 | 04:17 AM
  #42
35reilly's Avatar
35reilly
Originally Posted by Cux350z
If you have the money and want to hold the power...ATS across all damn day.
Hit up RHDjapan for the best price ( 800 lower that CZP, 400 lower than others) You will pay import fees but its not much. You will be about 2100 otd. You will need a new TOB and sleeve from nissan which is another 100.
http://www.rhdjapan.com/ats-carbon-t...33-vq35de.html
That is what I swapped to and love it. Hated OS giken with light flywheel.
MeanZ runs carbonetics which is the same as ATS...but carbonetics no longer exists.
Any suggestions on getting a install manual in English?
Old Feb 23, 2016 | 01:18 PM
  #43
Cux350z's Avatar
Cux350z
hatersgonnahate
Do you really need one? Just get the right TOB and sleeve and TQ specs and install it. Thats all i did.
PIcs of your parts?
Old Feb 23, 2016 | 02:14 PM
  #44
35reilly's Avatar
35reilly
PIcs of your parts?
No not really but there is specific directions on break in. I don't need any issues. There is also to copper washers big one and a small one.
Old Feb 23, 2016 | 02:15 PM
  #45
35reilly's Avatar
35reilly
Also you know the torque specs you used?
Old Feb 23, 2016 | 03:29 PM
  #46
Cux350z's Avatar
Cux350z
hatersgonnahate
http://www.2jzgarage.com/wp-content/...win.Triple.pdf
Old Jun 24, 2016 | 01:03 PM
  #47
35reilly's Avatar
35reilly
Getting close to installing my Ats triple. Want to know if the stock sleeve that throughout bearing is pressed on to will work also a factory bearing. Thxs
Old Jun 30, 2016 | 05:00 PM
  #48
OldManZ350's Avatar
OldManZ350
I installed the a Twin ATS, it's very nice. And it required a different Nissan sleeve. If you look on the website it shows what is required for your paticatular setup.
Easy install, just take your time and make sure you have the correct sleeve and bearing.
Install the parts in order just like it came from ATS.
Break in is about 800-1000 miles in stop and go traffic, no super hard driving.
Hope this helps
Old Jun 30, 2016 | 05:11 PM
  #49
Cux350z's Avatar
Cux350z
hatersgonnahate
yeah you need a new sleeve and bearing. Get them from the online oem nissan parts shops.
Old Jul 1, 2016 | 03:12 AM
  #50
35reilly's Avatar
35reilly
That's great. Cause I just ordered the oem sleeve and bearing. Smh. You have a part number?
Old Jul 1, 2016 | 05:28 AM
  #51
Cux350z's Avatar
Cux350z
hatersgonnahate
http://www.ppi-ats.com/carbon_clutch...10_Nissan2.pdf
Old Jul 1, 2016 | 08:56 AM
  #52
35reilly's Avatar
35reilly
Thxs bud. Any suggestions on where I can place this order for these? Place I got clutch from is a nightmare to deal with. In Japan
Old Jul 1, 2016 | 10:01 AM
  #53
Cux350z's Avatar
Cux350z
hatersgonnahate
just pick your favorite oem nissan parts dealer
who did you buy your clutch from?
Old Sep 15, 2016 | 12:38 PM
  #54
35reilly's Avatar
35reilly
Hopefully someone see this and can chime in and explain what these washers are for and where they go. Been looking over the manual and says nothing about these.
Old Sep 15, 2016 | 01:53 PM
  #55
Cux350z's Avatar
Cux350z
hatersgonnahate
mine are still sitting in the box.
Old Sep 15, 2016 | 01:55 PM
  #56
35reilly's Avatar
35reilly
Kinda figured but ya never know!!! So I'll take that as not used? Maybe for different car or something?
Old Sep 15, 2016 | 01:58 PM
  #57
35reilly's Avatar
35reilly
This maybe a stupid question but rather be sure then unsure. This how I'm pressing TOB in sleeve? Beveled up?
Old Sep 24, 2016 | 03:04 AM
  #58
OldManZ350's Avatar
OldManZ350
If you put the TOB Carrier only in the Freezer overnight it will get smaller.
Then grease up the surface.
Get a socket that is the same size as the inner bearing race and tap in on with a hammer.
Make sure that you get it fully seated.
Old Sep 28, 2016 | 05:19 AM
  #59
35reilly's Avatar
35reilly
FYI, if anyone is curious the ring/washer that comes with the ATS clutch goes on before you press bearing on. So sleeve , ring, press bearing. This is what RHDJAPAN got back to me with!! Might have been understandable if directions were in English!! Anyway that's how it goes so guess I will be pulling Trans off to install. Lol
Old Sep 29, 2016 | 07:30 AM
  #60
CK_32's Avatar
CK_32
Do you even JDM bro?
Lol
Amber Shook
Nov 19, 2015 06:45 PM
