Eagle vs BC rods strength?
Old Sep 9, 2016 | 06:47 AM
jdm-v35's Avatar
jdm-v35
yea I was planning 91 and water/meth. no 93 here that ive seen!
here is what ive found. everything else is 91.
http://www.cosportbikeclub.org/local/highoctane.html
found 2 e85 stations. about 20 mi away from me(not proven that they still sell it). the others are 50-100+ away
Old Sep 9, 2016 | 07:31 AM
thatv35guy's Avatar
thatv35guy
I'm just saying, with that compression and boost you're leaving no margin of error
Old Sep 9, 2016 | 07:48 AM
jdm-v35's Avatar
jdm-v35
I agree. I may reconsider CR, but we'll see as it gets closer. Reason I went with 11:1 is if I really wanted to I could stay NA and push nitrous instead. not the best for max power on boost, but it should handle decently if built properly. I may try and get tuned on 100+ octane since its more available than e85 here..
Old Sep 9, 2016 | 07:40 PM
Resmarted's Avatar
Resmarted
What pistons did you actually buy?
Because 11:1 is typically designed for NA... Meaning the piston strength won't be up to boost requirements. From what I understand, most NA pistons get material removed from them vs their boost counter parts, to save as much weight as possible. I'm not sure if the material changes too, because I know they put a priority on making the piston lighter. VS for boost you have to deal with a much greater thermal load, and pressure load.
If it's a NA piston not designed for boost, you might flat out break it.
If it's one of the custom high comp boost pistons then you'd be ok. But even then I don't like the idea of above 10:1 on boost. It works, but the extra power... I don't think is really worth it. There are other ways to get better response, and more power/spool that don't put your engine on the knife edge.
Old Sep 9, 2016 | 09:55 PM
jdm-v35's Avatar
jdm-v35
thanks for the input resmarted. They are wiseco 11:1 and actually heavier than the 8.8:1 pistons. so extra material and nothing removed and same material as the low comp version. With the tomei 280/11mm cams, that should help out on the compression a bit i'm guessing.
Here is the current parts list of what I Actually have now:
Wiseco 11:1 96mm pistons
HKS headgasket
ARP main studs
ARP l19 head studs
Tomei 280/11mm intake and exhaust cams
I also plan to call up wiseco to see if I can buy upgraded wrist pins if they make a heavy duty version.
Old Sep 10, 2016 | 01:41 AM
Resmarted's Avatar
Resmarted
HKS headgasket
ARP main studs
ARP l19 head studs
They do I have them. They're much much thicker and stronger. Heavier too obviously. Not too expensive either.
Old Sep 10, 2016 | 08:56 PM
jdm-v35's Avatar
jdm-v35
so the wiseco's should handle boost fine then? or a 250+ shot of nitrous, depending which route I decide to go.
Old Sep 11, 2016 | 08:10 PM
Resmarted's Avatar
Resmarted
I don't know of the specs of the 11:0 Pistons. But the ring gap will be very important in deciding what you can do to that engine. Same with the block machining. Wisecos require extra room for thermal expansion at the piston. They have more aluminum than JE etc pistons, so they expand more. This means you get some piston slap at cold start, but in theory the material will be "stronger"
Definitely should call wiseco and ask them what to do for clearances and to order those wrist pins. They know what they're talking about.
Old Sep 12, 2016 | 05:58 AM
jdm-v35's Avatar
jdm-v35
Thanks! Will definitely be giving them a call when i have some time.
Old Sep 12, 2016 | 05:40 PM
jdm-v35's Avatar
jdm-v35
havent called wiseco yet, but they have the pin upgrade listed in their catalog. It is the same material, just 1mm thicker walls. still worth it for the $80 that it costs though for a little more safety. will definitely pick them up.
I need to call them about bore sizing and wristpin/piston power handling at the same time.
Old Sep 16, 2016 | 05:39 AM
MM'08_350Z's Avatar
I like My BC Con Rods! They are holding just find.... 900+ ponies...
Old Sep 16, 2016 | 09:04 AM
jdm-v35's Avatar
jdm-v35
nice! thats great to know. are they the 625+ rods, or lower series?
Old Sep 18, 2016 | 03:13 AM
Resmarted's Avatar
Resmarted
Mine definitely were thicker than a 1mm bump, and looked to be a different material. At least that's what the machine shop said (not dynosty). Could be different now though.
Old Sep 18, 2016 | 09:01 AM
Engloid's Avatar
Engloid
If you guys have a link to the upgraded pins, can you post it up please?
Old Sep 19, 2016 | 08:01 AM
thatv35guy's Avatar
thatv35guy
http://realstreetperformance.com/Rea...at-Anchor.html
http://www.wiseco.com/Catalogs/Sport...ccessories.pdf
Wiseco's off the shelf wrist pin upgrade is the same material as their standard wrist pin, just 1mm thicker, I think they're $20 a pin.
Old Jan 18, 2019 | 08:17 AM
jdm-v35's Avatar
jdm-v35
Bumping this up again as i am back in the market for rods. Its been a while but still working on the build
Car has just been on the back burner sitting on a lift in my garage collecting dust. Also added a few more parts to the inventory though.
between pauter and carillo not sure which rods are the strongest.
jwt tt manifolds,
2x gtx2867r turbos
authentic greddy front bumper
authentic kenstyle sides
Old Jan 20, 2019 | 12:22 PM
BoostedProbe's Avatar
BoostedProbe
jwt tt manifolds,
2x gtx2867r turbos
OEM rods will almost handle 2867's power output.
Old Jan 20, 2019 | 05:32 PM
  #38
jdm-v35's Avatar
jdm-v35
Highly doubt that. Maybe if it was a single 2867
Old Jan 25, 2019 | 02:08 PM
  #39
0taku's Avatar
0taku
I'm using K1 rods for my build and I plan on pushing it past 850 with spray. (I'm also 11:1)
Old Jan 25, 2019 | 02:21 PM
  #40
jdm-v35's Avatar
jdm-v35
Ended up ordering Pauter rods. I think they should definitely be more than enough rod for my use!
Wrxst
Aug 31, 2016 05:30 AM
mas8394
Aug 24, 2016 06:07 AM
dragon11689
Aug 22, 2016 05:33 PM
813_350Z
Aug 14, 2016 12:06 AM
