Can someone look at some logs? Losing mind troubleshooting
Old Jun 28, 2018 | 04:24 PM
yosip1115's Avatar
yosip1115
Originally Posted by TT03Z
Sad part is I just put these in to fix a misfire.... I always put them in and tighten them the same way. I screw them in hand tight then feel the washer crush and go another 1/8th of a turn
Sounds about right, so blue brings up a good point, how much of it is stuck in there? the pic was sorta blurry
Old Jun 28, 2018 | 04:28 PM
TT03Z's Avatar
TT03Z
The entire threaded section and electrode is still in there. I ran to work to grab my easy out set hopefully those will get it out. Those plugs aren't exactly easy to find either I doubt anyone in town will have them but I still have the previous 2 sets I've changed. I hope that was my misifre issue. It ran fine without load but as soon as about 10psi came in it started breaking up pretty bad.
Old Jun 28, 2018 | 06:29 PM
yosip1115's Avatar
yosip1115
That is definitely your issue lol. I would never run those again.
If sht really hits the fan and something falls into the cylinder... (first off I'd say move it to tdc before beginning), but a vacuum with a small hose on the end will get whatever you drop out of there. Good luck
Old Jun 28, 2018 | 08:18 PM
TT03Z's Avatar
TT03Z
Got super lucky and it came right out. It definitely
was my issue haha I just put a used plug in it for now. Im racing in a stick shift noprep this weekend and won't have plugs in time so it's gonna have to work for now.
Old Jun 28, 2018 | 09:41 PM
bealljk's Avatar
bealljk
This is a significant issue on the Ford F150s ... I did spark plugs at 130k circa 2013 and three of my eight plugs were 'seized' in place. Lisle makes a decent tool (very similar to what TT posted up) and I was able to get all three out.
Since then I apply a generous amount of antiseize (on both vehicles)...I also count the number of turns I put on the plug - on my NGKs it's 17 via hand-tighten and then I use the torque wrench...
On my recent change, I dropped down two steps cooler and gap'd them to .028. I believe I will be replacing coils before any significant event as I believe I was missing at high rev / high loads ... I'm considering NGKs coil packs for the VQ - I think they are a solid company. If I can scratch it, I'll see about a higher end option ... After my epic fail FG hatch rescue I really want a dry carbon hatch...
Old Jun 29, 2018 | 03:20 AM
yosip1115's Avatar
yosip1115
Those are some nice easy outs
James I didn't know ngk made coils.for the vq that sounds pretty solid...
Old Jun 29, 2018 | 06:28 AM
bealljk's Avatar
bealljk
^I just googled them ... I think they are OEM replacements ... nothing special or upgraded...but if they work 'consistently' I'd be happy.
Old Jun 29, 2018 | 06:53 AM
TT03Z's Avatar
TT03Z
If your replacing coils I would recommend the Hitachi brand from Rock Auto. They were reasonably priced and haven't missed a beat in 2 years in my car.
Old Jun 29, 2018 | 07:31 AM
yosip1115's Avatar
yosip1115
https://www.z1motorsports.com/igniti...ck-p-7090.html
I went for those, 88 for OEM is not bad
Old Jun 29, 2018 | 07:45 AM
bealljk's Avatar
bealljk
I'm not married to anything ... I don't know that they are problematic ... I'm replicating the environment - 80 - 90 degrees, medium-high boost(15psi) and high engine speed, medium-high roadway speed and I can't get the problem to come back.
Maybe it was the spark plugs.
$88 isn't bad at all ... I thought Courtesy Parts had them at $120/each...
The NGKs are $400 for the set...
My first run on Day Two, I was coincidently paired with a hellcat (everyone here should know I am not a fan of the hellcat) and he beat me off the line by a solid half to full car... which makes sense ... I have minimal traction and some turbo lag to catch up on...but 40mph I was caught up and pulling on him ... Around 90mph I was well ahead of him and my car missed ... I immediately lifted and the hellcat passed me up ... it was rather disheartening so damn frustrating!!! If it means a new set of coils, consider it done!
Old Jun 29, 2018 | 07:51 AM
TT03Z's Avatar
TT03Z
I would knock your gap down to .022. and if it was a complete random misfire I doubt it was a coils fault. When coils fail it's "usually" an on/off senario. Also if u hate Hellcats that much I would've stayed in it and taken the win! Lol. I raced a few cars that on paper I shouldn't beat a few weeks ago and even though my car was breaking up I stayed in it to take the W and rub it in the faces of the 800+hp domestic V8's that I just drug there asses on 5 cylinders hahaha. The will to win was to strong to get out of it.
Old Jun 29, 2018 | 08:07 AM
bealljk's Avatar
bealljk
I think I will ... I pulled my heat range 6 plugs and I still need to adjust my fuel trims in the haltech ... I might run these a few more times on the car and see how they look, drop the gap to the .022 and she how she does.
I'm too big of a puss, and I'm hyper sensitive to listening to the car. I have too much in my setup to pop it over a dumb dodge! The car was bogging down and I don't even know if it'd have run if I stayed on the gas...
On the way back to the pits, I can only imagine the hellcat guy felt pretty lame that he beat me off the line and then got walked on ...
I smile... dodge just released the Hellcat Redeye (which is 797hp / 707tq) and they make zero comment about it dropping weight...if they could get that car down to 3600lbs and 18" lightweight wheels it'd be a wrecking crew.
I further smile bc I can add ~200hp to my setup and still drop another 150-200lbs
yosip1115's Avatar
yosip1115
USUALLY hahaha
thekyledeg
Tuning
Jul 25, 2015 12:58 PM
PearlZzZ
May 15, 2015 04:32 PM
mattleegee
Oct 5, 2011 03:42 AM
chefrey
Tuning
Apr 7, 2008 10:12 PM
GurgenPB
Jul 21, 2005 08:10 AM
