Priming new Engine with oil
Old Mar 4, 2019 | 05:18 AM
Staisman's Avatar
Staisman
Default Priming new Engine with oil
I know on other cars you just take plugs out and disconnect injectors and crank it. Withing 10 sec you would get 1-2 PSI of oil pressure. Well this doesn't work on VQ. After couple tries i have no oil in the oil filter and no pressure on the gauge. So how do you do this on the VQ ?
Old Mar 4, 2019 | 05:58 AM
rancor's Avatar
rancor
Use a pressurized fill system and attach it up to the oil pressure sending port. That will get oil in the galleries and bearings then just start the car. The motive 1735 power fill pro or many others, I think the LS needs a similar system, will work you just need a bspt adaptor and probably some more hose to conect to the system. If it's a new oil pump you might need to fill the pump with oil, assembly lube, or even grease to get it to prime. The oil pump relies on the oil to help it seal and create a vacuum.
Old Mar 4, 2019 | 06:14 AM
Staisman's Avatar
Staisman
Default Motive
Everything is new, new engine, new oil pump. I have motive 1735 and i also have those hand pumps that goes on qt bottle. What grease to use to fill the oil pump and what happens to it after all ?
Old Mar 4, 2019 | 06:43 AM
bealljk's Avatar
bealljk
did you use an assembly lube when you assemble the engine? I've heard vasoline works for pre-priming the oil pump.
Old Mar 4, 2019 | 06:52 AM
Staisman's Avatar
Staisman
Default Lube
Yes of course.
Old Mar 4, 2019 | 07:47 AM
bealljk's Avatar
bealljk
Yes of course.
(not being a doucher) If you used assembly lube do you feel it wont protect until you generate oil pressure? being cautious?
Did you use a mineral oil on components as well? Just curious what product you use??
Did you do billet gears in your oil pump?
Old Mar 4, 2019 | 08:06 AM
Staisman's Avatar
Staisman
Assembly lube and Conventional oil nothing else. No billet gears, just OEM rev up pump.
Old Mar 4, 2019 | 10:31 AM
OldManZ350's Avatar
OldManZ350
You have the Motive 1735, why are you not using it?
Old Mar 4, 2019 | 10:34 AM
Staisman's Avatar
Staisman
Default Motive
Didn't know I have to, everybody saying it should be easy 10 sec cranking. But apparently it's not.
Old Mar 4, 2019 | 11:09 AM
OldManZ350's Avatar
OldManZ350
I saw your post on the Engine Build.
Looking Good, Your doing a Nice Job...
Can't wait to hear it Run!
Old Mar 5, 2019 | 08:30 AM
Staisman's Avatar
Staisman
Does anyone run pre-oiler? Accusump or similar ?
Old Mar 5, 2019 | 12:03 PM
eZg's Avatar
eZg
I seem to remember Sasha using an accusump...........but he isn't around much anymore.
Bpb713
Dec 11, 2024 05:59 PM
Bmurray350z
Mar 11, 2018 03:37 PM
OldManZ350
May 2, 2013 08:26 AM
BerZerk
Jul 31, 2008 04:37 PM
