Hellcat 525lph Fuel Pump Install
Old Oct 23, 2020 | 04:29 PM
0taku's Avatar
0taku
Originally Posted by OldManZ350
Maybe so! But I don't want to predict some crazy Hp Numbers and not reach them.... LOL
Don’t blame ya, a lot of people keep asking me about what I’ll be reaching. I just guess 700-750.
Old Oct 25, 2020 | 09:56 AM
thatv35guy's Avatar
thatv35guy
I purchased the 525 Helcat Pump, but not Installed.
My biggest concern is that I will run out of Fuel.
The Street is not a problem, it will be very detuned maybe 26psi on pump gas.
At the Drag Strip I'll be Running VP Q16 & it 9.41% Oxygen.
Drag Setup: VQ35DE, 11/1, V7- YSi-Trim, 32, may as much as 36 psi with my front mount 5 inch bell mouth intake.
I'm expecting 800- 850whp min.....
Thought?
I'd definitely pair the fuel pump with a voltage booster (either a Kenne Bell or a JMS). Even if you could manage to make due with 525 pump alone you'll be at the jagged edge of that pump's capability, a voltage booster will give you additional stability and safety.
Old Oct 26, 2020 | 09:29 AM
thatv35guy's Avatar
thatv35guy
One other interesting tidbit on fuel pumps, pressure, and injectors I'll drop in this thread…
So obviously if you’re injector limited you can increase your base fuel pressure to get more flow out of your injectors.
I tried a pretty substantial increase in base fuel pressure to see how much more flow I could net. I ended up increasing the base fuel pressure to a 61 psi (61 psi w/vacuum reference line connected and 68 psi disconnected), this was up from my previous base fuel pressure of 43.5 psi. This increase netted me an additional 200cc’s of injector.
Unfortunately, this bump in fuel pressure created a new issue. Once the car was at normal operating temps the car started to run extremely lean at idle and the hotter the car got the leaner the car ran. I tried a large increase in fueling at idle but that didn’t work. What I eventually realized was that was just too much fuel pressure to run the car at idle, I think with that much fuel pressure/atomization the fuel was basically evaporating when it hit the hot manifold/cylinder port.
I found a happy medium at just over 51 psi (58 psi w/vacuum reference line connected), the car idled perfectly and I was able to squeeze an additional 100cc’s out of the injector (every 1 psi of fuel pressure netted +12.5cc’s of injector flow).
Old Oct 27, 2020 | 12:17 AM
bealljk's Avatar
bealljk
interesting for sure ...
my ID1000s are rated at 43psi and at our 52psi I am pushing a little short of 1100cc (1080cc?? IIRC??) But it does make sense that flow will go up with pressure.
Old Oct 27, 2020 | 07:59 AM
thatv35guy's Avatar
thatv35guy
Yeah, I've got DeatschWerks Denso bodied 1000cc injectors in my car, at 58 psi of base fuel pressure I'm getting about 1250cc out of them. *All numbers I'm getting from my ProEFI and they appear to be pretty accurate.
Old Nov 9, 2020 | 11:52 AM
aaronbc's Avatar
aaronbc
Update: I got everything installed (S1 return system, upgraded wiring, 525lph pump, 1000cc injectors). To flush out the line and test I just ran the fuel line into a gas can. Flow looked good. After that I connected the fuel line and pressure regulated at ~52psi with no apparent leaks. I can't start the car until I figure out how to tune things for the bigger injectors and uprev MAF GT after I install the supercharger kit.
I was able to use the stock fuel strainer and although the basket doesn't compress all the way, it compresses enough to fit in the tank. I know I'm close to bottoming out on the strainer but I don't understand why I would need more clearance. If needed, I could trim down the strainer a little to gain a few more millimeters. What is the purpose of the fuel basket compressing anyways? I don't see why it would move at all after being installed in the rigid fuel tank.
Thanks for the help!
Old Nov 9, 2020 | 05:33 PM
OldManZ350's Avatar
OldManZ350
The Biggest Restriction you have as far as Flow is the Feel Line.
CJM makes a -8 or 1/2" Feel Line that comes with the Stage 2 kit.
The Stock 350Z Feed Line is is Very Tiny.
crd00
Mar 31, 2014 03:27 PM
dskang100
Nov 11, 2008 09:53 AM
silver350tn
Sep 6, 2008 06:58 PM
cquence 350 [Z]
Oct 13, 2004 08:45 PM
