Crazy Bank to Bank Variance (Bank 2 Lean)
don't think its your fuel pump, your afr wb 1 seems ok, like I was saying you need to stay in 95 - 105, you need to look more into your data logs,
all your map1 fuel targets should be in closed loop, 14.7:1 at idle, and you have so much variations
99-125 at 888 rpm
94-103 at 850 rpm,
I would do a leak down test on bank 2 tdc on cylinder 2,4,6
make sure you plugged in the right wires to the injectors,
check that the wires are connected to the coils, in the right order
check spark plugs,
99-125 at 888 rpm
94-103 at 850 rpm,
check spark plugs,
99-125 at 888 rpm
94-103 at 850 rpm,
check spark plugs,
99-125 at 888 rpm
94-103 at 850 rpm,
check spark plugs,
All wires seem to be in the correct areas for injectors and coils.
Spark plugs look all okay but a bit white
Will the car still run without the VTC ?
Ill check all this out tomorrow as its been raining today
Yes, I had no VTC on passenger side. It can definitely cause the AFT differences between banks. We couldn't fix the problem on the dyno (swapped in new solenoids, changed the sensor, etc, etc). I ran it a whole year with no VTC with both connectors to the solenoids unplugged (and taped off). Found the problem in the pic over the winter and had to wait until next dyno session to get it tuned right.
I'm on Haltech, so I don't know if the stock ECU would throw a code, but it will run fine, just kills low end torque. Your tuner should be able to disable any codes. But you're best bet is to start by unplugging both and see if the imbalance goes away. If it does, you know it's VTC and can start troubleshooting. I'd then plug one side in at a time and see which side recreates the problem, that's the side that's working. If you've checked the solenoid for clicking, and the sensor at the back (it's a pain), pull the VTC cover off and check that seal piece.
2. How do you want me to send you the ROM? and is it looking like its being more of a tuning problem? than a mechanical problem?
It is a single turbo, im not sure exactly how far the turbo is from the wb sensors, but its a lot closer to the turbo on bank 2 than bank 1
