Boost on stock nissan oem ring gap
Old Jul 17, 2023 | 11:20 AM
YUHBOI350Z's Avatar
YUHBOI350Z
Default Boost on stock nissan oem ring gap
Im trying to do a mostly stock turbo build only looking for about 400 hp i was planning to only run about 8 pounds at most but dont now if the stock ring gap would be fine to run it on
Old Jul 18, 2023 | 07:19 AM
GreyZ's Avatar
GreyZ
DE or HR? Plenty of people running that boost on stock motors of both.
Old Jul 18, 2023 | 09:21 AM
bealljk's Avatar
bealljk
You wont have issues at 400hp mark - good question. Plenty of people have pushed their stock setup further than that without issue.
Old Jul 18, 2023 | 10:54 AM
YUHBOI350Z's Avatar
YUHBOI350Z
i have a 2004 de
Old Jul 18, 2023 | 12:28 PM
bealljk's Avatar
bealljk
Originally Posted by YUHBOI350Z
i have a 2004 de
I think Tim Hampton (OldManZ) was pusing close to 550hp on a stock block (albeit very low torque number comparatively) and did fine.
Welcome to the forum
what turbo kit are you going to go with?
what other mods are you planning?
You going with e85 or gasoline?
what are your intentions with the car?
Old Jul 25, 2023 | 04:15 AM
OldManZ350's Avatar
OldManZ350
8psi in not a Problem on a stock motor.
I ran 15-20psi for about 40,000miles @ 577/445 on race Gas.
Then the Rods finally bend after all the abuse.
Old Jul 25, 2023 | 06:53 AM
bealljk's Avatar
bealljk
Tim,
when you tore-down the engine did you find any abnormal cylinder wall wear (due to ring gaps)?
Old Jul 25, 2023 | 07:41 AM
OldManZ350's Avatar
OldManZ350
NO, The Motor Looked pretty much like New, except for the Bent Rods
Originally Posted by bealljk
Tim,
twitch579
Oct 11, 2010 09:49 PM
djtimodj
Mar 10, 2009 07:19 AM
ZainT
Jul 20, 2004 06:30 AM
enhanced
Nov 3, 2003 06:43 AM
