Greddy TT Power steering leak.
Old Dec 31, 2025 | 05:25 PM
hulkout's Avatar
hulkout
Default Greddy TT Power steering leak.
Curious if anyone else has run into this and what can be done to fix it. I’ve been just dumping fluid into the reservoir for like 10 years and my alternator is getting dripped into and my garage floor has a permanent stain.
This is the fitting included in the Greddy twin turbo kit and is the PS inlet to the pump from the reservoir. I had installed the OEM o ring where the red arrow is in the pic. It leaked so I tried a lot of things including 2 of the OEM o ring which amazingly worked the best but still a pretty bad leak. I tried an o ring at the red arrow, and RTV at the black arrow. Still leaked.
if I knew anyone who was able to weld the damn thing onto the pump that’s what I’d have done. But I do not…
help
Old Dec 31, 2025 | 10:22 PM
terrasmak's Avatar
https://www.chasebays.com/products/c...vSJ0jhGmb36300
indecided to google the pump and see what the original fitting looked like , see if t could be modded to work for AN fittings and saw this.
just an idea , I would probably look this way
Old Jan 1, 2026 | 07:15 AM
hulkout's Avatar
hulkout
You know, I’d seen that but kind of poo-poo’d it because the price is a little steep for my purpose. But after your suggestion, I poked around that site a bit more and found a swivel AN adapter.
https://www.chasebays.com/collection...-wrx-ej20-ej25
I bought a OEM PS pump with the fitting since my stock one is long gone. I’m going to try to make a stock one work and if I fail I can make the adapter work with some -10 hose I have in the garage.
thanks for the suggestion-it helped me get my brain churning.
DJShan209
Apr 9, 2009 11:54 AM
TurboSam
Apr 9, 2008 03:41 PM
pimpsahab
Nov 24, 2007 05:28 PM
minus500
Apr 12, 2007 07:09 AM
tecni
Sep 1, 2005 02:23 PM
