spool up with greddy tt
Old Mar 16, 2004 | 11:10 PM
03_ppw350z's Avatar
03_ppw350z
Default spool up with greddy tt
just wondering if you guys have alot of turbo lag? to me it seems like it lags till about 4000 rpm what do you guys think when do you reach boost
Old Mar 17, 2004 | 07:03 AM
etx's Avatar
etx
That is way too low. Sounds like you have a boost leak. What is your vac reading at idle? It should be ~-.7
I can build 3 psi in 5th at 2200 rpm. You could have an exhaust leak too. Did you remember to put the rings in the inlet side of your wastegates?
Old Mar 17, 2004 | 09:51 AM
03_ppw350z's Avatar
03_ppw350z
those little metel rings that taper down? if so i didnt put them in lol. my vacumer readings are like at -9 and it does lag
Old Mar 17, 2004 | 12:37 PM
fernandito7's Avatar
fernandito7
I am seeing the exact same spool up as 03ppw350z. I start to reach + boost at around 3600-4000 rpm and my vacuum readings around 2200 rpm is like 10 according to the e-01. im gonna check with my installer to see whats up.
Old Mar 19, 2004 | 08:00 AM
t32gzz's Avatar
t32gzz
Me too, almost no lag. I can build boost as low as 2300 in 4th. Something is wrong.
Old Mar 19, 2004 | 09:29 AM
etx's Avatar
etx
LOL! That's your problem. Those seat with the valve in the wastegate to seal. Have fun putting those in! matching up the wastegate/downpipe is the hardest part.
Old Mar 19, 2004 | 10:19 AM
03_ppw350z's Avatar
03_ppw350z
ah crap let the fun begin i told my friend too but he said they didnt fit lol o well luckly i dont mind woking on cars! thanks guys
Old Mar 19, 2004 | 11:50 AM
etx's Avatar
etx
yeah they fit, but they are tight. They don't actually go all the way in until you torque the WG all the way down.
Old Mar 20, 2004 | 05:36 PM
03_ppw350z's Avatar
03_ppw350z
man i put the rings in today all i can say is wow what a diffrence this thing feels so much better and spools like crazy now i also had to put new gasket since they all blew out due to not having the rings in place!
Old Mar 20, 2004 | 05:41 PM
phunk's Avatar
phunk
CJ Motorsports
awesome! good to hear you fixed the problem.
those rings are the replacable valve seat for the wastegate. They are the sealing surface for the valve inside there.
etx is right, they dont go in all the way by hand, once your torque the gate down they close the valve some.
sales@czp
Sep 23, 2019 03:30 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
