sync e-01 with aem wideband?
Old Apr 4, 2004 | 03:43 PM
03_ppw350z's Avatar
03_ppw350z
Default sync e-01 with aem wideband?
i bought the optional harness for an input signal with the eo1. im trying to sync my output wire of the aem with the e.01. i know the voltage is 0-5v but what do i set the conversion to on the e-01?
Old Apr 4, 2004 | 03:55 PM
etx's Avatar
etx
You should look into how much voltage the AEM puts out for a given ratio and sync it that way. For example, my timing retard map on the emanage goes by RPM / Boost sensor voltage from the e-01. The sensor put's out .1vdc per 1 psi. 15 psia (~ atmospheric) is 1.5vdc, Five pounds of boost is 20.5 psia so the voltage is 2.05. The AEM unit should work in a similar way. Maybe 0vdc is 10:1 afr and 5vdc is 20:1 afr. Call AEM they should be able to explain the output. Let me know how it works out as well, I have been planing on doing the same thing.
Old Apr 4, 2004 | 04:00 PM
03_ppw350z's Avatar
03_ppw350z
thanks man but im really bad at trying to figure this stuff out i think the aem starts at 11:1 af? but i dont know where it stops. i guess i should call aem monday hopefully they can help ill post whenver i find out becuase i know other people will want to be able to log onto the eo1!
Old Apr 4, 2004 | 04:52 PM
03_ppw350z's Avatar
03_ppw350z
ok i went to the aem website forums and i read that it s 11:1-18:1
Old Apr 4, 2004 | 07:51 PM
Guru's Avatar
Guru
All widebands are 0-1 v or 0-5 v. Just ask AEM which it is and use the output to connect to the corresponding input wire on the optional harness.
Old Apr 4, 2004 | 08:50 PM
03_ppw350z's Avatar
03_ppw350z
ive had it hooked up but you have to tell the eo1 how to translate the voltage. the aem is set to 0-5v default. on the e01 you have to tell it what a/f to read at the specified voltage. which would be 11:1-18:1 if the aem forums are correct.
Old Apr 5, 2004 | 08:02 AM
etx's Avatar
etx
Yeah, put in 0 vdc = 11 and 5 vdc = 18. Then take it for a run and see if the output of the wideband display is the same as what the e-01 is thinking it is.
Old Apr 5, 2004 | 03:36 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This is sweet...so if you get it working, I assume you can do full boost, RPM, and AF datalogging?? Sweet!
Old Apr 6, 2004 | 01:12 AM
03_ppw350z's Avatar
03_ppw350z
yep thats how it works bad *** huh!
Old Apr 6, 2004 | 06:11 AM
etx's Avatar
etx
Too bad the graph on the e-01 is so hard to read. I wonder if greddy has any way of exporting the data to a PC to review.
Old Apr 6, 2004 | 06:24 AM
jesseenglish's Avatar
jesseenglish
I know I talk about this wideband a lot, but the Techedge Wideband O2 can log A/F, RPM, 3 user inputs and 3 egt inputs. User inputs can be any sensor 0-5V. For example A/F, RPM, boost, Throttle position, intake charge temp. I'm waiting on my senders and that's exactly what I'll be logging in a week or so. They're all exportable to a PC.
Don't mean that as a downer on your AEM because the AEM display is much nicer. Just info for those who are looking to log data to a PC.
Old Apr 6, 2004 | 10:14 AM
etx's Avatar
etx
Well if that's what you want get this one. http://www.zeitronix.com I even logs EGT's which I have not seen on any other unit. This one is the least expensive I have ever seen as well. I am going to buy just the sensor and controller ($220) and use my profec e-01 to display the afr.
Old Apr 6, 2004 | 01:15 PM
Sharif@Forged
Forged Performance
03_ppw350z
When you get working, can you post a step-by-step?? I have the AEM and e-01 just waiting for install. I'll order the sensor harness.
Old Apr 7, 2004 | 12:40 AM
03_ppw350z's Avatar
03_ppw350z
its simple when you get the harness you wont be able to ready the instuctions at all there forighn lol. ok neways the white wire in the harness you are ordering will go to the white wire on the aem unit. simple thats it. now when you go to set the analog input in the e01 you set up using chanel one (white wire) you set the voltage to 0-5v and you set the conversion to 11:1-18:1 then you set the warning to whatever you want if you even want the warning feature. thats basicly it you jus set up the guage display to show channel one of the analog input. i found alot of info about the e-01 and all the optional harness including pictures and translations to the wire colors on this page: http://www.mohdparts.com/emanage/#Ma...0Installation:
Old Apr 7, 2004 | 12:35 PM
350Now's Avatar
350Now
03_ppw350z thanks for the link great info.
Old Apr 7, 2004 | 06:17 PM
Sharif@Forged
Forged Performance
http://www.savepic.com/is.php?i=4449...conversion.jpg
I scanned this in from my instruction manual.
Here is the table of voltage conversions for the AEM wideband. As you can see, it's different from what was posted earlier. The range is 9.72 to 19.56
Old Apr 8, 2004 | 01:26 AM
03_ppw350z's Avatar
03_ppw350z
thanks for updating us with the conversion mine was off!
Old Apr 8, 2004 | 05:12 PM
Sharif@Forged
Forged Performance
So is it working? If so, can you post a screen shot of your RPM/Boost/AF table on the Profec?
Old Apr 8, 2004 | 05:57 PM
03_ppw350z's Avatar
03_ppw350z
ill snap a shot tonight when i hed back up to the shop!
Old Apr 9, 2004 | 08:00 PM
Sharif@Forged
Forged Performance
03_ppw
I installed my AEM A/F today and I noticed that as my RPM increases at WOT, it very quickly goes from 13.0 down to 11.0 and then ends up flashing those dashes. This happens at like 3500rpm. Does the AEM only read to 11.0?? I figured it would at least goto 10.0 before pooping out.
Either way, I running MUCH richer than my tailpipe dyno measurement indicated. It showed me gradually maxing out at 11.4
