ETX---I am going to initialize my eManage--Help
Old Sep 10, 2004 | 04:49 PM
350G's Avatar
350G
Out of curiosity, how did someone obtain these basic emanage tables?
Old Sep 10, 2004 | 07:25 PM
phunk's Avatar
phunk
CJ Motorsports
those tables that etx posted are correct, and i ran them in the car and verified that the car ran exactly the same.
however everyone has failed to mention that there is another step you need to take, and that is the injector correction factor.
etx: not sure if you ever saw my post or not, but i had an idea for the airflow map... with the injector correction causing what is essentially a voltage clamp (since the MAF input never exceeds like 4.95ish or whatever, and the injector correction on top of that takes the output down to around 4.3ish which is the row where you end up doing most of you full throttle tuning)... i had an idea of using the airflow correction map to add back in fuel at higher RPM and throttle, which could POSSIBLY get some natural ignition timing retard out of the stock ECU since it will see closer to realistic engine load. What do you think?
-Charles
Old Sep 10, 2004 | 07:39 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
i still this its just easier and simpler to retard timing with the ignition timing harness. Keeps it simple.
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
