Back from the tuner
Old May 5, 2004 | 11:22 AM
booger's Avatar
booger
Default Back from the tuner
I just came back from having my G35 AT5 Dynoed and tuned. It was done on a Mustang Dyno ...Last few runs the temp was 84 deg. so I was losing boost .We started out the morning at about 67 deg. We didnt mess with timing at all , just the A/F . I ended up with 338.6whp at 6,400 rpm and 283.3 torq. at 5,900 rpm .He said that on a Dyno Jet dyno it would come out around 379whp and 312 torq . On a early run when it was cool I made 7.1 bls of boost at 6,400 rpm .The the boost on the last run was 6.6 bls . I will post the chart later today if I get a chance...if not I will thursday . I need to talk to some one that knows more about the timing side of it before We mess with it.....Back to the track...I need work on my reaction time and launch
Old May 5, 2004 | 11:36 AM
PoWeRtRiP's Avatar
PoWeRtRiP
sounds about right now bring us home some 12 sec slips!
Old May 5, 2004 | 02:54 PM
whosdady's Avatar
whosdady
The Mustang dynos I have seen have given higher numbers not lower? I also thought the stock vortech kit put out 8 PSI of boost opposed to 6.6 and 7.1? Granted I have heard the G's put out a little less boost but 6.6 is pretty significant.
338 rwhp seems right online with 6.6 psi. Any issues shifting in full auto mode?
Old May 5, 2004 | 04:01 PM
MIAPLAYA's Avatar
MIAPLAYA
On the contrary the last dyno day out here in SD for us on a Mustang dyno produced lower numbers than a dynojet did accross the board. It was an average of 20 below Dynojet the whole way accross the board. I think it has to do with how the weight is inputted into the Mustang dyno.
Old May 5, 2004 | 04:33 PM
booger's Avatar
booger
I have the rev limiter raise so it shifts in auto .When it does shift [ at WOT] it has...like a dead spot though...The Mustang Dyno...from what the operater told me runs 11 to 12 % lower than a Dyno Jet . But you can set it up any way you want to . The shop across town [ mustang also] has his set up to read like a Dyno Jet .
Old May 5, 2004 | 05:00 PM
zimbo's Avatar
zimbo
You might want to check to make sure your serpentine belt is tight enough. If you can turn it all the way upside down with your fingers without great difficulty then it's probably too loose and you'll lose a bit of boost.
The other thing to do is to do the run with the R4 software still connected and watch the fuel map. You can see if it makes it into the 8psi or 8.5 psi cells. Or, you can do a recording as I have described in another thread.
--Steve
Old May 5, 2004 | 05:31 PM
12SecZ's Avatar
12SecZ
My Edge Racing Converter eliminated that annoying "dead spot."
Something to think about especially if you want better launches and more torque for 392.00 bucks!
Thanks for keeping us updated.
Scott so now we have two at a minimum not sticking. You should have your car right now right?
Let us know and please email me two on my private email I don't always get the notifications from here to my Yahoo account.
Thanks (whosdaddy) and Booger
A5T's representing the 12's with juice!
Old May 5, 2004 | 06:43 PM
booger's Avatar
booger
--Steve
Yes I checked the belt between every run . I could only turn it half way . He said that we could probably make more HP and boost if we let it cool for a half hour [11 runs back to back] .I just tried to post the dyno sheet but its to dam big . There is that little dip around 5,700 rpm but it did lesson the more he adjusted fuel .We had the same problem like every one else after we up loaded the first time . Thing went to **** after 4,000 rpm .
Old May 5, 2004 | 07:12 PM
zimbo's Avatar
zimbo
But you knew exactly what to do, right?!
--Steve
Old May 6, 2004 | 07:46 AM
booger's Avatar
booger
--Steve
Well I did print out what you said to do....but..lol...I forgot to bring it with me...so we just called Split Second .As far as boost goes [getting only 7lbs] I believe its because of the headers ,cats, and cat back .There is less restriction .I am making just as much HP as every one else , so I'll be happy with 7lbs .I'll just keep close tabs on the belts .
Old May 6, 2004 | 07:51 AM
OldManZ350's Avatar
OldManZ350
I was getting about 7 lbs before correcting the belt problems. Now I'm getting 8lbs - 8.5lbs. Stock headers, No cats and Invidia exhaust.
Tim
Old May 6, 2004 | 08:01 AM
booger's Avatar
booger
Tim
Well thats good. What kind of HP you making ? And are you getting that boost reading from the gauge ?
Old May 6, 2004 | 04:34 PM
booger's Avatar
booger
Default Dyno chart
Here is the Dyno results .Remeber its a Mustang Dyno . No Dyno arguements Please . The guy that runs it has been doing it for 25 years , races Vett's , Pantera's , and some Drag cars .Tunes every thing and knows his stuff . I trust him and what he says when it comes to tuning a car and running a Dyno .We havent played with the timing yet . So there is more there to be had
Old May 6, 2004 | 04:42 PM
booger's Avatar
booger
http://www.nissaninfiniti.club.net/photopost/500/12056save0021-thumb.jpg Ok try again
Old May 6, 2004 | 04:50 PM
booger's Avatar
booger
Ok what the hell am I doing wronghttp://www.nissaninfiniti.club.net/photopost/data/500/12056SAVE0022-thumb.JPG
Old May 6, 2004 | 05:24 PM
zuff's Avatar
zuff
your link isn't valid that's what's wrong!
sales@czp
Sep 23, 2019 03:30 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
