Greddy TT Owners--Important Warning
Old May 16, 2004 | 12:12 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Default Greddy TT Owners--Important Warning
You may want to double check your metal power streering lines that run across the bottom of the car, and run right up against the passenger side turbo exhuast housing...ouch. It's the same area where you wrap the fuel lines and stuff.
While I was under the car at Street Image, Jeff (350ZNow) noticed the PS line was actually touching the exhuast housing...woops. We felt the line at it was clearly burred...but not broken. The same thing happen when 350Znow installed his kit, and the PS line melted in a day. I've been driving for 2500 miles.
Greddy doesnt mention this line, or the need to heat wrap or move it. We did both. There are some nuts right in the center of the car...just follow the line back. If you loosen the two nuts, you can move the line slightyly to the left, and give yourself an inch of extra room. Then heat-wrap for added protection. If you havent done so already, heat wrap the starter plastic housing...that thing is really close to the turbo exhuast housing as well....not good.
Attached is a pic of the line as Eric at Street Image wrapped it, and then secured it with safe wire...
Old May 16, 2004 | 12:50 PM
Akira's Avatar
Akira
Thanks for the heads up
Old May 16, 2004 | 01:28 PM
350Now's Avatar
350Now
Actually the turbo over time will burn through the metal PS line. Make sure you move it and give it some air-space between the turbo and the metal line.
Old May 16, 2004 | 06:07 PM
etx's Avatar
etx
Hah! Funny you mention this. I replaced that line with a rubber line on friday. It wore all the way through the hard line. I moved it over when I installed the kit because it was so close, seems it shifted back over. Oh well... Good thing it's just a return line, no pressure.
Old May 16, 2004 | 06:17 PM
350Now's Avatar
350Now
Yeah I notice it's not pressured. I just temporarily sealed up the hole with Permatex Gasket Maker. It holds pretty well and should be able to withstand high temp. Quick and cheap solution for now.
Old May 17, 2004 | 08:03 AM
etx's Avatar
etx
Removing the hard line was the hardest part. Thank you roto-zip!
Old May 19, 2004 | 12:37 PM
t32gzz's Avatar
t32gzz
Thanks GQ, I will check this out.
Old May 21, 2004 | 10:13 PM
Sharif@Forged
Forged Performance
bump for safety.
Old May 22, 2004 | 07:18 AM
m3powerrr's Avatar
m3powerrr
wish I still had my power steering.
Old May 22, 2004 | 08:58 PM
Sharif@Forged
Forged Performance
M3.....how is your car/cars coming along? I havent head you posting much, but i remember you were aggresively tuning the Greddy TT, and had another built engine ready to go...in case the stocker blew. What's the status?
Old May 24, 2004 | 05:27 AM
m3powerrr's Avatar
m3powerrr
It's still where I left off. I haven't had much time to do any additional work on it lately. I still have the exhaust leak so I need to take it apart and check to see if all the parts mate up. As far as the tuning goes, we still havent' pushed it to the limit yet. I'll post something as soon as we see soem good numbers.
Old May 24, 2004 | 02:38 PM
Sharif@Forged
Forged Performance
m3power, pretty much everyone with the Greddy kit has an exhuast leak of varying severity where the wastergate connects to the downpipe adaptor. Since Greddy supplied cheap paper gaskets, everyone has burned through them and had leaks. That would be the first area to address. Turbonetics sells a deltagate wastegate metal gasket that fits perfectly with the Tial wastegates....FYI
416blueZ
Jun 11, 2024 10:56 AM
sales@czp
Sep 23, 2019 03:30 PM
416blueZ
Sep 24, 2015 02:11 PM
