Vortech Air Filter Removal Secret
Old May 17, 2004 | 03:13 PM
OldManZ350's Avatar
OldManZ350
Default Vortech Air Filter Removal Secret
Does anybody know how to remove the Vortech air filter without destroying it?
Is it even posible without removing the blower?
Old May 17, 2004 | 03:24 PM
baptist's Avatar
baptist
I'd love to know this as well. Cant see any way of doing it without taking the blower assembly apart.
Old May 17, 2004 | 03:56 PM
SungNamZ's Avatar
SungNamZ
Vortech SC goes on within the next two weeks. While it won't stop me from installing, good information to know!
Old May 17, 2004 | 04:07 PM
booger's Avatar
booger
I dont think there is any other way .Was looking at it the other day wondering the same thing .I was thinking just to take it back to the shop twice a year and have them do it and clean the oil spray thingy and replace the belts . Im lazy and dont like working on cars that much...I get to frustrated
Old May 17, 2004 | 09:02 PM
pimprider2000's Avatar
pimprider2000
here is what my installer came up with.........
Old May 17, 2004 | 09:18 PM
UsafaRice's Avatar
UsafaRice
That just strikes me as kinda funny. I mean, you take in air from the front, compress it and heat it in the S/C, run the air through the IC to cool it off, and then that "cooling" air that came through the IC gets sent back into the Vortech. I mean, you're sucking in your own heat to have to cool it off again! (to use that heated cooling air again... ad infinitum)
I'm sure it works fine though, it's just the principle that makes me chuckle.
Old May 18, 2004 | 03:17 AM
zimbo's Avatar
zimbo
My installer came up with a similar solution except that the filter is accessible via the wheel well similar to a CAI.
Anyone know the diameter of the Vortech filter?
--Steve
Old May 18, 2004 | 05:17 AM
tig488's Avatar
tig488
um, it doesnt go back into the vortech once it comes out of the IC, it goes straight into the intake. im sure thats what you meant, right?
Old May 18, 2004 | 07:29 AM
CaneZMD's Avatar
CaneZMD
No, he means that the air that passed through the IC to cool the intake charge is the same air that is getting taken up in through the air filter. (in that placement.)
Hey zimbo, post some pics please. I'm gonna be installing soon, and I'd like to figure this out before I start.
Old May 18, 2004 | 10:54 PM
importriders's Avatar
importriders
Has anyone thought about using the Procharger filter assembly? Looks like you might be able to use the Procharger tubing on the Vortech.
Old May 20, 2004 | 07:33 PM
CaneZMD's Avatar
CaneZMD
Hey Zimbo, got any pics??
Old May 20, 2004 | 07:41 PM
zimbo's Avatar
zimbo
Here's the idea... some sort of 3.5" tubing from the mouth of the turbine down in into the area where a CAI filter would go. The filter they put on the end of the tubing is a 7" long K&N filter. Sorry I don't have any pictures behind the wheel well so you can see--but it basically just hangs down. Removing the filter is as easy as removing the front left wheel and pulling down the wheel well cover.
--Steve
Old May 20, 2004 | 09:57 PM
narkotic's Avatar
narkotic
Interesting how you put your cog belt on... Instead of over the top of the tensioner pully, i'ts underneath... When vortech did my install (first official G35 kit) they put it over and i've always kept it that way..
--Steve
Old May 20, 2004 | 10:36 PM
tig488's Avatar
tig488
mine is under also.
Old May 21, 2004 | 06:22 AM
zimbo's Avatar
zimbo
I never thought about that! I'll have to look to see if mine will fit that way because as it is the cog belt is quite close to the intake. BTW, how tight is your cog belt?
--Steve (first unofficial G35 kit )
Old May 21, 2004 | 07:53 PM
huducks's Avatar
huducks
dollar99 has the same tubing as zimbo. i'm still trying to figure out where to aquire the tubing. ne one know??
Old May 23, 2004 | 01:44 PM
narkotic's Avatar
narkotic
Hmm, as mine is it's very very close to the intake tube as well.. i'd say 1/8th of an inch now... scary.
Old May 23, 2004 | 07:51 PM
tig488's Avatar
tig488
the side thats close should be the bottom part, so it wont help if you run the belt over the pulley.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
