f/i g35 gauge(s) placement?
Old Jun 10, 2004 | 05:39 PM
freezeg35's Avatar
freezeg35
Default f/i g35 gauge(s) placement?
As the autometer pod does not fit and currently nothing else avaliable, where have you f/i g35's put your gauge(s). Im thinking of making a plate for 2 52mm gauges in the nav/cubby storage. Any input and pictures would be appreciated. TIA
Old Jun 10, 2004 | 05:48 PM
SammyJL's Avatar
SammyJL
Default Re: f/i g35 gauge(s) placement?
I had a custom fiberglass pod made. Not the best solution but it works for now.
Attached Thumbnails f/i g35 gauge(s) placement?-120_2038_50k.jpg
Old Jun 10, 2004 | 06:12 PM
SQUILL's Avatar
SQUILL
Default Re: Re: f/i g35 gauge(s) placement?
What do you mean ??? That looks pretty sweet to me!
Old Jun 10, 2004 | 06:21 PM
booger's Avatar
booger
Default cubby
I put mine in the cubby...but the angle isnt very good...it does hide them , and that is what I was going for
Old Jun 10, 2004 | 09:06 PM
freezeg35's Avatar
freezeg35
sammy can you get another one of those i think it looks great. If so how much, do they still have the mold?
Old Jun 11, 2004 | 06:25 AM
SammyJL's Avatar
SammyJL
Default Re: Re: Re: f/i g35 gauge(s) placement?
They didn't use a mold, they just mounted the guage holders on the existing pillar and fiberglassed over them. It was pretty easy for them to do and any decent bodyshop or performance shop should be able to do it and it shouldn't cost that much. I had them paint the passenger side the same color so that it would match.
Old Jun 11, 2004 | 09:41 AM
joenismo's Avatar
joenismo
I just datalogged boost and A/F to my profec E-01. I wanted a very clean appearance on my interior. My pics are shown on a thread a page or two back under profec e-01 flush install. The screen is very visible while driving. Once you get your A/F and boost set, you shouldn't have to monitor them every second anyway.
Old Jun 11, 2004 | 10:02 AM
kzanard's Avatar
kzanard
Installer put them in nav cubby. I have since had them switch out autometer A/F for AEM wideband (in middle). They said it was a tight fit but it looks good in my opinion. Really stealth with cover closed.
Attached Thumbnails f/i g35 gauge(s) placement?-gage2.jpg
Old Jun 11, 2004 | 05:01 PM
freezeg35's Avatar
freezeg35
kzanard, what brand of gauges are you using. Also when they ran the wires from the back of the gauges did they drill a hole out in the bottom of you nav/cubby and just pull the wires thru or did they have to take the dash apart to get at the wiring. Also do you have any more close up pix? TIA
Old Jun 13, 2004 | 12:51 PM
Eagle1's Avatar
Eagle1
Here is a link to pics of my gauge installation, which utilized the nav cubby space, and the glove box.
Initially I wanted the lid to close on the cubby, but the visibility was compromised and I wanted to use the larger 60mm face meters, so the custom mold is what you see. The meters in the glove box are canted to the driver, and when the door is close they are out of sight.
http://www.imagestation.com/album/re...?id=4287816943
Old Jun 14, 2004 | 09:04 PM
freezeg35's Avatar
freezeg35
Nice. is it a mold or did they just glass around the placed gauges?
Old Jun 15, 2004 | 05:33 AM
kzanard's Avatar
kzanard
Freezeg35,
That was an old pic (I need to take new ones). In the pic they are all Autometer 52mm gauges: Boost, A/F, EGT (left to right). I threw out the useless narrowband A/F and replaced with AEM wideband A/F. I had a shop do the installs and they told me it was labor intensive. I guess the entire center console needed to come off to get at the cubby and for proper wire routing.
~KZ
JjL
East Canada
Jun 12, 2019 03:04 AM
Vigman
Nov 17, 2015 04:34 AM
Depravity
Oct 1, 2015 04:49 PM
