What else is needed to install Vortech?
Old Jun 12, 2004 | 01:07 PM
zachcrosen's Avatar
zachcrosen
Default What else is needed to install Vortech?
You can look at my sig to see what mods I currently have. I am trying to see what kind of costs I would be looking at to go with a Vortech. I looked on here but couldn't find exactly what i was looking for. What other items are necessary for this install in addition to the SC itself? I am not looking to go for 500HP or anything, just something faster to play with. Thanks in advance for any feedback.
Zach
Old Jun 12, 2004 | 01:09 PM
zachcrosen's Avatar
zachcrosen
Also, what does anyone know about www.superchargersonline.com ? I got a quote on their satin Vortech SC at $4647.23 plus $48-50 shipped. What would be a reasonable cost for installation? What is a reasonable cost for tuning? Thanks again.
Zach
Old Jun 12, 2004 | 01:35 PM
booger's Avatar
booger
Zach
Superchargersonline is where I got mine thru..$.4,350.00 shipped . As far as other things you will need...wideband O2 sensor...boost gauge . Look for an installer thats worked with Vortech SC,s before or that has done an install on a G or Z . $ 1,000.00 to $1,400.00 to install
Old Jun 12, 2004 | 01:36 PM
dfw350z's Avatar
dfw350z
I got my system installed and tuned for $1,700 by the dealership.
[URL=http://www.grubbsinfiniti.com]
Old Jun 12, 2004 | 01:43 PM
teh215's Avatar
teh215
Really you don't need any additional modifications to the motor. The kit is designed to work on a completely stock motor. You may want to get a cat-back exhaust and replace the test pipes with resonated pipes or hi-flow cats. The Kinetix plenum may be a problem on a FI motor but, I have not seen any proof that it will be. I did my own install that way I knew it was done correctly. Not that an installer couldn't have done it, I just don't trust someone that I do not know working on my cars. My 2¢.
Old Jun 12, 2004 | 02:00 PM
zachcrosen's Avatar
zachcrosen
I was looking for info along the lines of what Booger gave. Sorry for the ignorance, but what exactly is a wideband o2 sensor. Could you point me to a website that has one or what kind do you have? Do I need to upgrade plugs will the OEM ones suffice?
I suppose any shop that does Vortech installs would tell me exactly what I would need, but it's always good to get info first.
TEH215, why would I want to swap the test pipes for something else? Thanks again guys.
Old Jun 12, 2004 | 02:07 PM
zachcrosen's Avatar
zachcrosen
Is an ECU reflash required or will it just help to increase power?
Old Jun 12, 2004 | 02:17 PM
CaneZMD's Avatar
CaneZMD
wideband O2 measures the Air/fuel ratio with better range and resolution than the factory O2. Factory O2 is meant to measure close to the stoichiometric A/F ratio which is 14.7. Since FI uses A/F's of 12 or so, you need a wideband.
Old Jun 12, 2004 | 02:26 PM
zachcrosen's Avatar
zachcrosen
Have you had any problems with the Kinetix plenum and F/I?
Old Jun 12, 2004 | 02:50 PM
coletta z's Avatar
coletta z
I also want to know why we should get rid of the test pipes from my understanding the test pipes cause the vortech to run a little leaner but if it comes from them tuned really rich it should be ok I would think.
Old Jun 15, 2004 | 11:56 AM
LaPuLaPu's Avatar
LaPuLaPu
Upgrade your flywhelel and clutch
BEBO'S ZEE
Jun 7, 2016 07:48 AM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
