Vortech or Stillen...Help me...
Old Jun 28, 2004 | 01:44 AM
  #41
Dan Ferraro's Avatar
Dan Ferraro
With ANY forced induction application, the less exhaust restriction you have the more power the engine will produce. You want the largest primaries available. Whoever said headers and hi-flow cats will reduce power doesn't have any clue to what they are talking about, especially with FI!!!
Old Jun 28, 2004 | 06:08 AM
  #42
jimthegreek's Avatar
jimthegreek
I was told by 3 different people at Stillen that you should have a somewhat restrictive exhaust system on the vehicle for the supercharger to build up boost, otherwise the vehicle just spits it all out and loses it.
They recommended a exhaust system and that was it. No headers or cats or test pipes. with their Stage 4 kit coming kit, they said it will work with their headers as well.
Old Jun 28, 2004 | 06:51 AM
  #43
2003z's Avatar
2003z
I'm sorry, but you are wrong. I gained 20hp by replacing my test pipes with stock cats, and my fuel flow richened. Its due to their system not sensing full boost with a less restrictive system, and thusly not properly enriching the fuel.
Old Jun 28, 2004 | 10:41 AM
  #44
jpc350z's Avatar
jpc350z
[QUOTE]Originally posted by 2003z
I'm sorry, but you are wrong. I gained 20hp by replacing my test pipes with stock cats, and my fuel flow richened. Its due to their system not sensing full boost with a less restrictive system, and thusly not properly enriching the fuel. [/QUOS
Something not quite right here. To attempt to achieve the designed Volumetric Efficiency of an I.C Engine you must fill the cylinders to their max capacity (A/F mixture assuming timing and injector pulse etc. are correct for the loading conditions.)Any restriction to exhaust flow which prevents this filling will prevent the Engine from achieving its V.E for the conditions of the engine loading.
Also during the intake stroke the exhaust valve is closed allowing the boost pressure to build up. Why would the system not sense full boost. Bad valves? Comments would be appreciated. Thanks
Old Jun 28, 2004 | 01:30 PM
  #45
Gary Evans's Avatar
Gary Evans
Default Exhaust Restriction
More exhaust restriction is never a good thing for FI or NA but FI has two related issues that can affect the potential benefit.
One was already alluded to and that being that the A/F must always be correct.
The second is valve overlap. At the top of the exhaust stroke the exhaust valve has not yet fully closed and the intake valve is opening. This is done so that at high speed the gas transfer speed is improved due to its inertia. On FI it is sometimes beneficial to reduce the overlap since with a pressurized mixture more may escape. If overlap isn't reduced the less exhaust restriction and/or higher boost will increase lost through the exhaust valve.
http://www.AzBikeTech.com
Old Jun 29, 2004 | 07:00 AM
  #46
zparts's Avatar
zparts
Default Re: Exhaust Restriction
Yea, what Gary said...The VQ35 has 14 deg. of valve overlap where the VQ30TT (300Z TT) only had 6 deg. This ,not to mention VVT programed for NA, makes a huge difference.
Old Jun 29, 2004 | 01:26 PM
  #47
Z ELIMINATOR's Avatar
Z ELIMINATOR
If what you are saying is right then if I remove the headers, cats
and reinstall the factory headers and cats I should get back at
least 20 hp at the wheels. I just wasted 4500.00 cdn and now
have to pay another 600.00 to get back 20 hp.
There should be a warning from stillen about this to people
before they by all the stillen toys for the Z and then find out
their car does not run right.
Old Jun 29, 2004 | 03:02 PM
  #48
techz33's Avatar
techz33
if the belt goes out, there will be no boost, but you will be ok. I have the stillen, for about 5000 miles now, 1 dragstrip day and 3 days on the racetrack without problems. I am burning excessive oil, but I don't think its stillen related, since several early vin people have had this problem. I love the stillen and would do it again. its the only mod I feel I got my money's worth out of. I have the stage 3, and I bought it used, so I don't have the warranty. However, due to the fact they offer a warranty, and got their CARB exemption on the 1st try, plus their engineering background and relationship with nissan, I'm not worried about it.
BURNING OIL MEANS ITS GOING TO BLOW TAKE IT IN TO A TUNER ASAP AND BUILD THAT MOTOR
Old Jun 29, 2004 | 03:39 PM
  #49
Gary Evans's Avatar
Gary Evans
If what you are saying is right then if I remove the headers, cats and reinstall the factory headers and cats I should get back at least 20 hp at the wheels. I just wasted 4500.00 cdn and now have to pay another 600.00 to get back 20 hp.
My comments were not intended as a blanket indictment against free flowing exhaust for FI but rather what could happen. The only way to know for sure what a combination of parts will make is to try them.
Old Jun 29, 2004 | 04:48 PM
  #50
2003z's Avatar
2003z
If its blows, I will rebuild it myself. Thats the only way I know it will be done correctly. I wonder how I would tune this baby bored out to 4.3??
Old Jul 2, 2004 | 11:44 PM
  #51
DanF's Avatar
DanF
If Stillen is saying THEIR supercharger requires back pressure, and they are also saying THEIR headers will work with THEIR supercharger, then they are also saying THEIR headers are restrictive. I have to laugh at this.... That is some very interesting marketing. I'll take note and not follow their cue. LOL
2003z,
just how does their system "sense" boost? And you can not "enrichen the fuel", just the mixture. The mixture is determined by the computer. If you are running too rich or too lean then you would have been better off doing some tuning rather than replacing hiflow exhaust components with the stock components.
It seems like Stillen is trying to cover themselves.
Old Jul 3, 2004 | 05:27 AM
  #52
jawbone's Avatar
jawbone
[QUOTE]Originally posted by DanF
[B]If Stillen is saying THEIR supercharger requires back pressure, and they are also saying THEIR headers will work with THEIR supercharger, then they are also saying THEIR headers are restrictive. I have to laugh at this.... That is some very interesting marketing. I'll take note and not follow their cue. LOL
ok, lets try this...on a few applications eg the one above and various motors I have seen at my shop, increased exhaust scavenging will cause a decrease in performance. By increasing the exhaust flow out you need to get more in right? A lot of times on positive displacement blowers (roots) you will need to increase blower speed to get back a slight drop in MAP caused by the freely flowing exhaust. However if you have to speed the compressor up too much then you increase the heat generated into the charge.... dillema! Z parts and Gary are good about noting the overlap concerns on boosted cars.. I have seen guys come in with wild cams on t/c cars and by killing some overlap (decreasing scavenging) they run sooo much better. Actually, if you call stillen R&D they will tell you NOT to run headers with their current blower for that very reason.... Do a little research and you will see this is true
Old Jul 3, 2004 | 08:45 AM
  #53
2003z's Avatar
2003z
2003z,
I know you can't enrichen the fuel, its semantics.
They sense boost by running a vacuum line to their piggyback. I think jawbone summed it up nicely in the above post.
Old Jul 5, 2004 | 12:07 PM
  #54
DanF's Avatar
DanF
Interesting... I am anxious to see the results of a local car we have been working on. We did 1 5/8" headers and 2 1/4" exhaust. Cats were replaced with 2 1/2" pipes. He picked up 22 HP to the wheels. Last week an associate installed the Vortech system on the same car. He picked up 105 HP to the wheels. Next the car will be coming back for 1 3/4" primary headers and dual 2 1/2" exhaust. It will be interesting to see if he gains or loses power...
Old Jul 5, 2004 | 12:39 PM
  #55
DanF's Avatar
DanF
Old Jul 5, 2004 | 01:31 PM
  #56
Mean Gene's Avatar
Mean Gene
Lightbulb Stillen Hood Option
I have plans for the Stage 4 Stillen kit myself because I AIN'T gonna fight my Borla headers again!!
I spoke with some folks @ Stillen last week & they said that they're working on a new style hood due to the complaints around the current version ( & it's "second" lump in the middle ). The swept-back cowl induction look is OK with me but it's that other lump that makes it look like an afterthought. BTW - Stage 4 will not be ready until the end of the year ( or so I'm told ) but it will be considered "off-road" useage only because it is designed to work with test pipes as well. Guess it's nitrous until then!!
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
AbyteZero
Sep 22, 2015 09:17 AM
Calinismo350z
Sep 14, 2015 04:04 PM
