vortech ss box map
Old Jun 25, 2004 | 09:47 AM
coletta z's Avatar
coletta z
Default vortech ss box map
Does anybody have a tuned map that they could e-mail me so I can get a base line of what is wrong with mine preferably someone with a 5 a/t I dont know if that will matter or not.
Thanks
Old Jun 25, 2004 | 04:31 PM
coletta z's Avatar
coletta z
Anybody?I just need a comparison so that I can see what vortech did and what most tuners are doing.
Old Jun 25, 2004 | 04:53 PM
dfw350z's Avatar
dfw350z
You can download mine to review.
http://www.dfwg35.com/download/G35.mdb
Old Jun 25, 2004 | 05:05 PM
coletta z's Avatar
coletta z
Thank you
Old Jun 25, 2004 | 05:22 PM
booger's Avatar
booger
Default map
dfw350z....what program do you use to open that file ? Cant find one that opens it
Old Jun 25, 2004 | 05:24 PM
dfw350z's Avatar
dfw350z
Default Re: map
I use the split Second software to open and manage my settings.
http://www.splitsec.com/products/r4softw.htm
What are you using.
Old Jun 25, 2004 | 05:25 PM
coletta z's Avatar
coletta z
open it in the r4 program under customer file
Old Jun 25, 2004 | 05:30 PM
coletta z's Avatar
coletta z
Now what I dont understand is your values dont really change under map a untill after 9 psi and untill 12 psi under map b.Am I reading this wrong?
dfw350z's Avatar
dfw350z
How do mine look compared to yours..
Old Jun 25, 2004 | 05:38 PM
dfw350z's Avatar
dfw350z
Unfortunately I don’t have my laptop with me otherwise I would look at it with you. I just happened to have the file in my DB. What I can tell you is my last dyno run / adjustment in R4 was to tune for A/F ratios, HP is not my objective it just happens. I am sure others that are after HP could make further modifications to the map for additional gains.
Note: If memory serves MAP A is Fuel and MAP B is timing.
Old Jun 25, 2004 | 05:42 PM
coletta z's Avatar
coletta z
It kinda does the same thing with just with different values but I must not understand how to read it right .Because all the numbers I see that are gradually increasing or decreasing are after 9 psi or after 12 psi and I know that its only a 8 or 9 psi pulley and boost is not going that high.I guess I have to do some more homework.
Old Jun 25, 2004 | 05:44 PM
zimbo's Avatar
zimbo
coletta, you must change your R4 preferences to display vacuum/pressure or you'll be interpreting it wrong. Open the customer files and then go to File | Options | System Settings and choose the Vacuum/Pressure option on the left side of the dialog box.
--Steve
Old Jun 25, 2004 | 05:45 PM
dfw350z's Avatar
dfw350z
I can recommend someone to call if you are interested. He preformed the base tune on my car.
GRUBBS INFINITI, LTD.
1661 West Airport Freeway
Euless, TX 76040
Toll Free (866)-789-0203
Ask for John in Parts
Old Jun 25, 2004 | 05:50 PM
coletta z's Avatar
coletta z
Ok that definatly made more sense thanks zimbo.
Old Jun 25, 2004 | 05:57 PM
zimbo's Avatar
zimbo
DFW, I like the way they did your timing map. Looks good. What's interesting is that you're giving the car less fuel than I am everywhere except at idle, even though we have just about the same list of mods. I'm running fairly rich during the summer, however (paranoid I guess).
--Steve
Old Jun 25, 2004 | 06:04 PM
dfw350z's Avatar
dfw350z
--Steve
Would it be possible to see your MDB file for comparison?
Also, do you have Dyno / AF sheets to reference?
Old Jun 25, 2004 | 06:10 PM
zimbo's Avatar
zimbo
I'm going to dyno on Monday or Tuesday (I just added a Methanol injection kit so I'm going to test it out) and I'll post the results after that.
--Steve
Old Jun 25, 2004 | 06:12 PM
dfw350z's Avatar
dfw350z
--Steve
Tell me more about this Methanol injection kit. Link/web site etc..
Old Jun 25, 2004 | 06:16 PM
zimbo's Avatar
zimbo
http://www.smcenterprises.com/injector_kit.htm
I'll post some pics in a different thread after I do the before/after dyno testing.
--Steve
Old Jun 26, 2004 | 08:17 AM
tig488's Avatar
tig488
are there any differences between 6mt and auto when it comes to ss settings?
